Cab Mounts/ Bolts
What is the best way to remove cab bolts this is a 83 cab and you cant see them trew the floor. i cut the floor and cant figure out how to get it out.
any suggestions?? also putting the cab on a 75 blazer frame and bought 75 cab mounts. mounts say i have to reuse stock spacer. the 83 ones look like the wrong spacers. here are some pics. what do the 73-80 spacers look like. 83 mount ![]() instructions ![]() stock mount diagram ![]() rear mount. ![]()
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) |
#2 | |
Re: Cab Mounts/ Bolts
If its the nut thats spinning, the front nuts can be accessed by cutting an access flap into the side of the cab support. The rears I think you need to get to from up top. Mine came out so I didn't need to explore cutting for the rears. Alex. |
any pic of the style body mounts used on 73-87 still cannot understand what is going on.
Robert Olson Transport
![]() Join Date: Oct 2002
for three days prior to removing the bolts i sprayed them twice a day with PB Blaster then i would loosen a bit then tighten then unloosen a quarter turn and back.. all the way out these things were bad and i was able not to spin the nuts that way
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
They should come out..I'm in the Northeast, I just put a pipe on my wrench and pulled them out..They twisted a little but they came right out with about 3 pounds of rust.
