Old 03-21-2023, 01:47 PM   #1
oldtrux
oldtrux's Avatar
Tach help please
Anyone familiar with this tach? 6-8 cylinder??
oldtrux is offline   Reply With Quote
Old 03-21-2023, 04:18 PM   #2
scottofksu
scottofksu's Avatar
Re: Tach help please
I can't offer much in the way of which engine this tach will work for, but I can say it looks to be a later unit if its factory (i.e., without a transmitter box).
I did find this post that includes a picture of an OE-1 by member 1963c-10. Not sure if they are still on here or if that was their tach that was pictured. I believe what you have is a V8 tach, but I am not certain.
https://67-72chevytrucks.com/vboard/...=392461&page=4
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old 03-21-2023, 04:57 PM   #3
oldtrux
oldtrux's Avatar
Thank you,I appreciate the help!!
Old 03-21-2023, 05:04 PM   #4
oldtrux
oldtrux's Avatar
I guess my next quest will be can i make it work with an hei dizzy? Nothings easy lol
Old 03-21-2023, 05:44 PM   #5
Arne
Arne's Avatar
Take a look at this. Pretty sure the owner (Bob Ashlock) can set you up, regardless of what the original tach was for.
https://ashlocktech.com/tach-adapt-1
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
覧覧覧覧覧覧
Arne is offline   Reply With Quote
Old 03-21-2023, 08:18 PM   #6
oldtrux
oldtrux's Avatar
Thank you!
Old 03-21-2023, 09:07 PM   #7
bhap
bhap's Avatar
Ron at Williamson's Instruments in Arkansas is top notch. He just repaired an old Sun tach for me by converting it to solid state. Super nice guy and quick turnaround.
bhap is offline   Reply With Quote
Old 03-22-2023, 07:15 AM   #8
oldtrux
oldtrux's Avatar
I will check this out, thanks!
Old 03-23-2023, 12:01 AM   #9
Nanook
Nanook's Avatar
100% agree...just purchased one of his units and I am using an original 8 cyl tach with a 6 cyl. (It also will work with the HEI)
Nanook is offline   Reply With Quote
Old 03-23-2023, 10:24 AM   #10
oldtrux
oldtrux's Avatar
Thanks,i have reached out to him!
Old 03-23-2023, 11:14 AM   #11
MikeN
MikeN's Avatar
If that tach works with a points-type distributor, it should work fine on an HEI. There is a TACH terminal on the HEI, just run a wire there from the DIST terminal on your tach.
MikeN is offline   Reply With Quote
Old 03-23-2023, 11:19 AM   #12
oldtrux
oldtrux's Avatar
Oh that would be nice! I will give it a shot!thanks for help
Old 03-23-2023, 01:16 PM   #13
oldtrux
oldtrux's Avatar
Ok,so I reached out to Bob at ashlocktech and he told me I should be fine with my DUI HEI dizzy. He went out of his way to research my dizzy to find out! As was mentioned above what a super knowledgeable and nice guy!! Thanks so much for the great info.
Dan
