Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Old 08-02-2012, 06:57 PM   #1
SunSoaked
SunSoaked's Avatar
WTB-NV4500-Bellhousing-NP241
Looking to locate a good used NV4500 out of a 4wd and a NP241 T-Case and Bellhousing. I want the bellhousing with the external slave cylinder (not inside the bellhousing). I believe the early (93-95?) models were external.
Would prefer a matched set but will take them separately.
Thanks, Mike
SunSoaked is offline   Reply With Quote
Old 08-24-2012, 11:09 PM   #2
Ronaldo
Re: WTB-NV4500-Bellhousing-NP241
I have your NP241. It was in a 91 silverado and behind a SM 465 manual trans.. I dont know if it will work for you, but its like new. Your in luck, im in AZ also...
Ron
200 bucks.
928-242-4717
Ronaldo is offline   Reply With Quote
Old 08-25-2012, 05:27 PM   #3
SunSoaked
SunSoaked's Avatar
I dont think it will work if its out of an IFS truck. The drop has to be on the Pass Side to work with my Dana 60 in my 69. I have been searching hi/low and have been "schooled" since posting this ad. I should have put it in the 73-87 section, since only the trucks will have what I need up to 87 (Burbs to 91).
If however, its a PS drop, I'm interested in it. Let me know. If not,I'll have to pass. Thanks for your time either way.
Mike
Ron
200 bucks.
928-242-4717
Old 09-17-2012, 03:03 PM   #4
jrsavoie
Be careful to check any NV4500. Count splines to make sure the input and output are GM.
There are 2 different transmission to bell housing bolt configurations.
In about 96 they quit using the GM bolt pattern and went to the Dodge bolt pattern for the 4 12mm x 1.75 bolts that hold the trans to the transfer case
98 GMC Suburban 2500 6.5 4x4 235,000 mi, FS2500, 96 GMC 6.5 Suburban 1500 4x4 280,000 mi; Amsoil 95 Tahoe 2 door 4x4 6.5 280,000 mi; 91 international 4700 low pro, spicer 6 speed, DTA 360 with 18' van box 500,000 miles plus.1994 chev K3500 crew cab SRW 5 speed 4x4 245,000
jrsavoie is offline   Reply With Quote
Old 09-24-2012, 03:23 AM   #5
83GMCK2500
External clutch slave cylinder is 92-94 with the oddball bellhousing to trans bolt pattern. GM input shafts are all 1-1/8" 10-spline with a pilot snout diameter of 0.590". The 4x4 NV-4500 has a 32 spline output shaft. Look for an NP-241 that is behind a TH400 or 4L80-E to find the correct 32 spline input gear.
Worthy to consider: Build the correct case from 2...go ahead and find a driver's side drop case from an IFS truck that has the 32 spline input gear, then source a 241 from a square body, split it and put the correct gear in.
I am collecting parts for my NV-4500 swap, so I've researched as well. I started with a 2WD trans and I've collected the 4WD tailshaft, I need the Mainshaft, the balancer, a spacer, and a couple little internal doo-dads + whatever else my trans might need in R&R. I removed it from a '93 C3500 with a seized 6.5L-TD so I didn't get to test it. I have 2 NP241s, both of them out of 90/91 squares with Electronic VSSs, one has 27-spline input from a TH700-R4, the other is the correct 32-spline from a 4L80-E.
Need trans parts? Looky here, they have good used & tested parts for decent prices: http://www.tbtrans.com/transmission_parts.htm
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
