how low
If I put bags on the front of a 63 how many inches of drop would I get completely aired out with no modification to the lower a arms? and if they are completely fill how much lower than stock would it be? and what would be the first thing that would stop the truck from going any lower other than the bump stops and tires.
Who Me?
Re: how low
The front crossmember will be about 1.5" off the ground. Here is a pic of my 65.
![]() Here is a pic with no spring before the bag went in. It airs out the same. ![]() Here is a side shot. There is about a 4 inch notch in the rear. ![]() Hope that helps.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Re: how low
When you say 4" do you mean 4" above the top of the frame rail? If so I assume you had to go into the bed a bit?
Who Me?
Re: how low
The bottom of the rear end housing was level with the top of the frame.
Re: how low
great thanks.
biohazardbill I think he means 4 inches higher than the bottom of the frame. |
Re: how low
Do you have bad camber issues with bags and stock control arms?
I am considering bagging my truck prior to buying new wheels and the 5 lug conversion. So i could put in bags in the front and a porterbuilt c notch in the rear? |
Re: how low
When you do the 5 lug conversion are you getting new spindles? Drop spindles would help with that I would think.
Re: how low
I already have 2.5 drop spindles and a disc brake kit. Just going to 5 lug for wheel choices
Posted via Mobile Device |
