Old 09-08-2012, 11:30 PM   #1
Belairbob
Drive shaft support bearing question
72 lwb I'm trying to resurrect. I was under the truck at the back of the transmission and pushed up on the drive shaft. It moves a 1/2" or better up and down in the support bearing housing. Time for a new bearing - right?
Thanks, Bob
Belairbob is offline   Reply With Quote
Old 09-08-2012, 11:34 PM   #2
69GWC
Re: Drive shaft support bearing question
Sounds bad to me.
69GWC is offline   Reply With Quote
Old 09-09-2012, 12:03 AM   #3
bollybib
bollybib's Avatar
This is probably the easiest and cheapest thing to try first.
http://www.napaonline.com/Catalog/Ca...087_0065479592
In Posts #72 thru 74 of my Project thread I relate my experience with this thing.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 09-09-2012, 10:55 AM   #4
Belairbob
Thanks Jim! Lots of good information and how to you posted for us!
Bob
Old 09-09-2012, 11:23 AM   #5
Fldawg
Fldawg's Avatar
Bob, been thru this just get a good bearing, the cheap ones last about 6 months, beausethe mounting backet is only tack welded in a couple spots, if you can get a SKF bearing there made in canada and spot welded in 8 places and welded down the sides great bearing hav'nt a probelm since i installed it, should run you about 40-45 bucks.
Fldawg is offline   Reply With Quote
