Painting question
how much humidity is to much to paint bc/cc?
Re: Painting question
Depending on color, I try not to spray if over 85%. But there have been hard times or times when I was really up against the clock and have painted and it was raining[some like it cause the dust threat is lower at that time] and it not seem to make much difference. I think it is more detrimental on a single stage paint than a dual staged one. In the past, the single staged type paints would have a tendency to turn a chalkly [er] color when painted in a high humidity situation. Jim
i am in the up against the clock situation. i finally have a weekend off and a truck ready to paint. now i have the leftovers of issac to deal with. i am hoping to be finished before the bad rain hits.
Grandpa in the rustmobile...
Anxioius to see some pictures!!!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Spray it [and blame me if it does'nt turn out ok, no, don't do that] I say your gonna be okay. What color are you going with anyway? Like I said before the upside to doing it in the rain is the thrash in the air is knocked WAAAY down and makes for a lots cleaner paintjobs. I know that when my filters are dirty in my paintbooth I get a cleaner job if it is raining as it rains the dust out of the air. Jim
meowMEOWmeowMEOW
I've done a little work in a hot garage in about 80%+ humidity, and its tough for a couple reasons.
It gets hot and steamy, and you risk condensation forming on stuff and/or ending up on your paint, and if you don't have a really big compressor that doesn't have to run often...you'll find that your comp pushes lots of water, and you'll be emptying both the on-tank and inline water separators often
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
The main reasons I have troubles painting with humidity, I am way too heavy[acutally I am the perfect weight for someone who is 8'7"] I am on medications that make me sweat and my booth is a metal box inside a metal shop so it is about 10 to 25 degrees hotter than the outside air sometimes. All of those thing combine to make my main problem possible sweat dripping on the surface but this happens any time the temp is over about 70 degress. Anything over 80 and I have to change clothes at lunch and hotter still I have to take as many as 5 or 6 showers daily. Dang. See you just think you got problems till you hear someone elses then you think man I'm glad I am not him. well, your welcome . Now go spray and have fun. Jim
i got it done here are a couple of pics. i am going to re do the bed in the morning i have to many light spots and i am not happy with it. it turned out pretty good other wise. the cab turned out great. here is a pic of my redneck paint booth too. it was 120 in the booth this afternoon so it baked the clear well and me too.
the cab
I think the humidity did mess you up. Take an 80 grit DA to it. Nah, just messin it looks good. I don't think you could tell any weather problems from looking at that truck. Like I said in an above post, it is an old wives tale mostly devoted to single stage paints and that does have some effects on weather when painting but not as much on the basecoat/clearcoat type. Good job. Jim
i meesed my self up more than the weather. i have a couple spots that i drug my shirt across trying to get the center of the hood. i think it will wet sand and buff fine.
not an old wives tale exactly...if you shot old school lacquer 40 years ago the stuff dried so quickly moisture couldnt evaporate out before it flashed.the condition was called blushing ,the paint dried with a cloudy white haze in it that wouldnt buff out.enamels dried slower and werent affected...modern urethanes dont seem to have problem but i'm still paranoid...I would caution anyone using duplicolors quarts of lacquer that they might have problems,but don't know cause i've never shot duplicolor
