Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-13-2012, 01:05 AM   #1
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Ok, Turbo Tech Question/Thermodynamics question
Procharger doesn't make a bracket to put one where i want it....so I'm looking at going turbo again. That said; does crossover pipe length matter? As a part of that, does UNEQUAL crossover pipe length matter?
Let me clarify. If I build a single turbo, it needs to mount off to the side and just forward of my passenger side head (lq4). I would use truck manifolds or my LS2 manifolds flipped. This means that the pipe from the passenger manifold to the merge at the turbo flange would be like 14", but the crossover from the drivers side head would be like 34". I'm used to seeing "equal length" turbo manifolds or twins. Is this a problem, with one side feeding air "faster" or am I just over thinking it, and it would just get lost in the ether with all that air flow.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-13-2012, 08:54 AM   #2
norm roll
norm roll's Avatar
Re: Ok, Turbo Tech Question/Thermodynamics question
it has never been a problem for me with offset turbo and unegual cross over pipe
norm roll is offline   Reply With Quote
Old 09-13-2012, 11:53 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thanks norm thats what I was hoping to hear!
Your engine bay is purrty.
Old 09-13-2012, 02:22 PM   #4
Super73
Super73's Avatar
Seen lots of single turbos off to one side with unequal length up-pipes.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-13-2012, 02:55 PM   #5
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Yes, single turbo it will be fine. If you were doing twins, you'd want them equal length.
Ryan
1969 Chevy milk truck
Old 09-13-2012, 04:20 PM   #6
norm roll
norm roll's Avatar
thanks this is my first time with a turbo and efi so im learning i had to hire some of the tunning and still messing with boost controller and ign comtuter and the big stuff 3 computer.
i know i can buil boost pretty quick with this large turbo it is a p/t 101 rated at 2100 hp
so i'm pretty sure you can do what i did on the location of yours.
so how do you think my turbo engine is going to look in my 66 chevy short bed step side lol. well it may go there but would use a 80 to 88mm turbo on it.
Old 09-14-2012, 12:10 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm sure it would look just fine!
I had looked at the 76, 80 and 88mm turbo's for my application. I won't reach the power limits of any of them most likely, as even the 76 is good like 700. I'd be running a cam only motor with the turbo, until I feel like opening it back up again to do more internal work.
Old 09-19-2012, 01:09 PM   #8
Wasted Income
Boosted Member
Wasted Income's Avatar
This is my setup, and it works great. Unless you are after a max-effort, razor's edge setup, the hotside piping is very forgiving, regarding routing, lengths, etc.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
