Old 09-05-2012, 08:16 PM   #1
B_derK20
I think I just broke something...
I was backing into my parking spot at home just now and something happened to the clutch when I pushed it in. The pedal now won't disengage the clutch. Nothing appears broken and all of the return springs are where they should be. It's an '83 so it's mechanical linkage. Any ideas? Is a broken clutch fork common or could it be a messed up throw out bearing? With the engine running the clutch doesn't make any unusual noise either with the pedal in or out. I'm stumped.
B_derK20 is offline   Reply With Quote
Old 09-05-2012, 08:29 PM   #2
76stepsidechevy
Re: I think I just broke something...
Crawl underneath and look to see if ball end of the mech linkage has popped out of the clutch fork. It happened to me, the adjuster was worn and bent. Suprisingly the sm465 is pretty easy to speed shift.
76stepsidechevy is offline   Reply With Quote
Old 09-05-2012, 08:29 PM   #3
J Knight
J Knight's Avatar
Sound to me like the clutch broke, probably time for a new one.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 09-05-2012, 10:13 PM   #4
tucsonjwt
Check the LMC catalog online for a good diagram of the mechanical clutch linkage, etc. x2 - crawl under the truck and see how you truck matches the diagram. I suppose it could be something simple like you lost the nut completely on the end of the adjustment rod, but you can see a lot just by looking around down there with a flashlight. I have an 83 SM465 and they are fairly simple -you can see everything mechanical easily under there.
tucsonjwt is offline   Reply With Quote
Old 09-05-2012, 11:35 PM   #5
CentipedePerformance
CentipedePerformance's Avatar
I had a Honda that spit out a dampener spring and it got wedged between the flywheel and the clutch, effectively locking it together. The clutch pedal had no effect on it whatsoever.
CentipedePerformance is offline   Reply With Quote
Old 09-06-2012, 12:04 AM   #6
B_derK20
Everything underneath looks ok. The clutch fork isn't flopping around so it must still be on the pivot ball. The adjusting rod is still intact and in the correct position too so the problem must be inside the bell housing. I SO did not need this right now...
Old 09-06-2012, 12:12 AM   #7
rcbildr
rcbildr's Avatar
Have you checked the z bar to see if the arms have "torn" from the welds?
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 09-06-2012, 07:34 AM   #8
xrcr
check the end of the rod and pivot cup(?) to see if worn
xrcr is offline   Reply With Quote
Old 09-06-2012, 08:38 AM   #9
sethv
sethv's Avatar
Check the Z-bar. Mine busted before.
1981 K10 Scottsdale
305 ci | TH350 | NP208 |
60k miles
sethv is offline   Reply With Quote
Old 09-11-2012, 02:30 PM   #10
Greg924
sounds like it has a collapsed pressure plate.
Greg924 is offline   Reply With Quote
