Old 09-17-2012, 04:17 AM   #1
wwj75c30
wwj75c30's Avatar
more inches on my dually..
So i want to get some more inches on the front on my 75 c30 while i keep it a 2wd i already have 2 1/2" coil spacers up front and i want it up to 4" susp and ill do a 3" bl. can i get any lift springs and add my spacers? i know for a 1/2 ton you use 1ton bbc springs. can i get heavier springs or lift springs? if i have to ill double stack spacers or something. anyone got any ideas? i need help and opinions. and no i dont wanna hear it needs to be lowered cuz its 2wd. so any lift help apprciated thanks
75 c30 silverado drw 454/th400hd d70 soon to have d60 up front
73 c20 custom deluxe sm465 14bff parts truck
wwj75c30 is offline   Reply With Quote
Old 09-17-2012, 09:56 AM   #2
manimal
manimal's Avatar
Re: more inches on my dually..
Instead of doing something that could get you killed(double stacking coil spacers) Why not find an off road fab shop that will build you a set of control arms and a "GOOD" shop will also be able to get you the right coil springs.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 09-17-2012, 10:07 AM   #3
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
This. The coil spacers you have already have you near the limit of your downtravel. Stacking spacers or lift springs will only make it worse. If you are wanting more lift, it's time to start looking into having it custom fabbed. There are a few ways to go about it, and it may take a combination of them to get where you want it such as lift spindles (fabbed or adapting a later model application, which will require steering and control arm modifications to keep the steering and handling in check), longer and offset control arms, or a drop subframe to lower the lower control arms for more lift, this will also require modified spindles or upper control arms to match.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 09-17-2012, 03:31 PM   #4
wwj75c30
wwj75c30's Avatar
how would a a 3" body lift be tell i can afford a dana 60? i might go to my friends custom truck shop and see what he can do
