Fabricate till you "puke"
Tork specs,front hubs 02 silverado?
Does anybody have the tork specs for the 3 bolts that hold front hubs to the knuckle(2wd silverado 1500)? Also , my guess is a couple drops of locktite on the threads wouldnt hurt? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
![]() Join Date: Sep 2005
Re: Tork specs,front hubs 02 silverado?
i did look up the torque spec but it doesn't show one in my repair info i normally clean teh bolts up and put a dap of locktite on them and runn them in with an impact gun
just found ti the hub to knuckle bolts are 133 ftlbs
Thank you much....crazyL
Thanks from me too.
