Old 10-17-2012, 05:45 PM   #1
McMurray76
snow plow mount pics
I know some of you out there are using these trucks to plow snow. What do your plow mounts look like? ANYTHING has to look better than mine! LOL
McMurray76 is offline   Reply With Quote
Old 11-11-2012, 11:28 PM   #2
FrankieD
FrankieD's Avatar
Re: snow plow mount pics
That is ugly
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 11-12-2012, 05:15 PM   #3
johnnyclack
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
The bolts should hold the major part of the load.
The only benefit you "might" gain from the weld may be to keep the bracket (& bolts) from becoming lose. Welding the bolts would have worked much better.
My guess is low amperage and not grinding the paint down to bare metal prior to attempting to weld...
johnnyclack is offline   Reply With Quote
Old 11-13-2012, 11:45 AM   #4
FrankieD
FrankieD's Avatar
If I were you I would make new mounts to be on the safe side
Old 11-13-2012, 11:50 AM   #5
johnnyclack
Yes I agree, if you have the resources, replace by all means.
Do keep in mind the less heat you apply to your frame horns, the better off you'll be in the long run.
Frame heat = brittle steel
Old 11-14-2012, 12:24 PM   #6
McMurray76
I'm DEFINITELY making new mounts. I just needed some inspiration. After some online research I think I'll mount reese receivers to the frame horns, and fabricate plow mounts that I can remove. Thanks!
Old 11-14-2012, 04:37 PM   #7
FrankieD
FrankieD's Avatar
check this out
http://67-72chevytrucks.com/vboard/s...d.php?t=544333
Old 11-14-2012, 04:49 PM   #8
McMurray76
Thanks FrankieD. Alot of good info there!
