Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-24-2012, 10:23 PM   #1
BIGTEN
BIGTEN's Avatar
Turbo on a sbc?
I have a turbo thats not being used and I know someone has put one a on sb but my question is how and can you run it with one header without connecting the both? The turbo is a t4 Garrett. Any suggestions, pics would be great.
BIGTEN is offline   Reply With Quote
Old 09-25-2012, 12:04 AM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Turbo on a sbc?
On one header..... Easy,,, you put one just like it on the other side.
Seriously. I doubt you would build enough boost to make it worth the plumbing exersize.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 09-25-2012, 03:31 PM   #3
BIGTEN
BIGTEN's Avatar
Re: Turbo on a sbc?
How much boost do you think it will push out. My engine is completely stock so...
Old 09-26-2012, 12:04 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Turbo on a sbc?
Single turbo no crossover tube will be completely non functional. You would need twin turbo's as stated.
And fwiw, Garett and T4 are not sizes. Garrett is simply the manufacturer, T4 is the flange type. We'd need to know what the actual turbo specs are....my guess is its a takeoff, and probably way too small for the engine.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-28-2012, 12:52 AM   #5
longbed67
longbed67's Avatar
Re: Turbo on a sbc?
Correct... and dont jump the gun! T4's depending on the trim of the wheel went up to 1.19 a/r on the exhaust which is more than adequate for any small block. Like BR3WCITY said we need specs on the turbo including a/r on the exhaust side and the wheel measurements on the cold side to determine the trim #. Then we need to know how many cu in your motor is. After that we can help you
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
