Old 10-12-2012, 10:59 AM   #1
hpcgmc
hpcgmc's Avatar
Need help getting rear drums off - puller?
I'm trying to get the rear drums off my 67 GMC. Apparently I haven't checked the rear brake pads in 20 years or so - probably because I couldn't get the drums off! I've tried pb blaster, hitting as hard as I can with a deadblow hammer, trying to pound them off from the backside, etc. The e-brake is off, the brake adjusters are turned as far in as possible, there are no threaded holes to put in a bolt, and no clips or screws holding the hub on (all of these have been suggested in the numerous posts I've read).
Has anyone see a puller that is large enough to pull a drum brake? The biggest I found at Harbor Freight is only 10", and the hub is about 12". I checked Autozone for their tool rentals and they don't have anything big enough.
It seems like just hitting it with a hammer is not doing anything. The hubs will wiggle a little, but I can't see any movement between the hubs and the center of the axle.
Any ideas would be appreciated!
1967 GMC 1500 SWB. Driving this truck since I was 14.
hpcgmc is offline   Reply With Quote
Old 10-12-2012, 10:57 PM   #2
hpcgmc
hpcgmc's Avatar
Re: Need help getting rear drums off - puller?
Well, it took some work, but got them off. The key seemed to be finding the right size tool to pry the hubs from the backing plate. I used an L shaped arm off of a gear puller. This allowed me to pry on the hub and create a gap between the hub and the axle - I shot a bunch of PB blaster in the holes, so it would penetrate behind the hub, then beat on it with the deadblow hammer while prying. I rotated the wheel around and pried with the gear puller arm - around and around, til it popped loose.
I bought the biggest gear puller at Harbor Freight, but it wasn't big enough. I think that would have done the trick if it was big enough.
Hope this helps someone else.
Old 10-15-2012, 07:53 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
I always try to put a little never seize around the center hub of the axle when I reassemble the brakes.
This will help keep the drums from rusting to the axle.
Glad you got yours off.
Keith
Convert to disc brakes.
Old 10-15-2012, 10:19 AM   #4
hpcgmc
hpcgmc's Avatar
Good idea on the never seize. I just put some bearing grease on the hub and backing plate in hopes that will help me get them off in the future.
