Old 10-24-2012, 08:14 AM   #1
sumtercleaner
sumtercleaner's Avatar
Shifter linkage
Does anyone make a "stock" replacement linkage kit? (72 c-10 AT) or is the universal kit a good choice? Thanks and this place is FULL of so much info
sumtercleaner is offline   Reply With Quote
Old 10-24-2012, 11:58 AM   #2
69gmcc10
69gmcc10's Avatar
Re: Shifter linkage
welcome to the board! I have never seen one new for sale. I think your options are to rebuild one or buy an aftermarket. I went with the lokar unit it saves space to run exhaust and eliminates allot of moving parts from the system, it does take a little adjustment to get rightbut for $50 it was way worth it.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 10-25-2012, 07:41 AM   #3
sumtercleaner
Re: Shifter linkage
Saw that one on tv actually. may go that route! Are rebuilding parts available ?
Old 10-25-2012, 09:04 AM   #4
LEEVON
Moderator
LEEVON's Avatar
Re: Shifter linkage
Nobody makes a stock set-up. The lokar kit isn't bad but it has problems, first being that it's a "one-size-fits-all" application. The linkage isn't in the right geometry and the hardware is prone to come loose. I'm basing this on several installs in different vehicles. It's usable, but the original set-up works much better. If you can find a good used one on here that's the way to go, what you need to look for is metal-to-metal wear. I managed to find one that had been blasted and like new for about $30.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
