Old 11-04-2012, 09:42 PM   #1
JJAB
6.0 Install Question
What do you think guys? I just finished an complete LQ9 install. Nelson performance custom harness, GM Hot Cam, long tube headers, built 4L60 tranny.I haven't received the custom tune as of yet, the tuner basically went in and did the basics until the custom tune is performed. Heres the question, I am getting a P0300 check engine code(Randon cylinder misfire). Coil packs, wires, 02sensors, spark plugs, 317 cylinder heads, all is brand new. Any thoughts or suggestions? I have sprayed around the intake and sensors with carb spray and have found no air leaks.
P.S. Took her for a test drive today and she really, really runs. Boy Oh Boy!!!!!!!!!
JJAB is offline   Reply With Quote
Old 11-04-2012, 09:48 PM   #2
AJII
AJII's Avatar
Re: 6.0 Install Question
The cam will throw random misfire codes if the misfire detection number is not increased. That's probably it.
If you have an aftermarket converter, that'll cause it to.
I wouldn't worry about it.
1985 K10 Under Severe Reconstructive Surgery
5.3/New Paint/New Interior/Yadda Yadda Yadda
AJII is offline   Reply With Quote
Old 11-05-2012, 08:55 AM   #3
whitels1
whitels1's Avatar
I second that, I have a Hot Cam in my LS1 Z28 and it throws random multiple misfires if idling for long periods.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 11-05-2012, 10:16 AM   #4
Wasted Income
Boosted Member
Wasted Income's Avatar
You need to do a CASE relearn with the new converter if it's a different diameter/mass than the stocker. That could be causing your misfire codes.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 11-05-2012, 12:16 PM   #5
OldCreek
OldCreek's Avatar
Have you manually checked each fuel injector? I had to pull and check each injector to find that one was stuck. My ohm meter didn't pick it up. You could try using a stethoscope on each injector, also. If these are the original injectors I would definately check.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 11-05-2012, 02:19 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm with the guys on the Misfire count number.
Large cam on low lsa means that the cam and crank position sensors will be putting out readings that will be too far "apart" and it will trigger random misfire codes. Also if your throwing misfire codes your converter won't want to lock up, or will unlock randomly if it does lock up.
A tuner should be able to adjust the misfire count in HPT and it won't trigger faults anymore.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-05-2012, 05:01 PM   #7
JJAB
Smile Re: 6.0 Install Question
Thanks to everyone who offered their suggestions and advice. The tuner is supposed to do his magic this Wednesday.
Old 11-05-2012, 06:41 PM   #8
harnalien
TruckincrazY
harnalien's Avatar
Is your tuner out of Waco? Interested in hearing how it turns out.
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 11-06-2012, 10:57 AM   #9
JJAB
He actually resides in Bryan, TX. He is making the trip to Waco to do the inperson tune. I will keep you in the loop as to how it turns out. This will be his fourth tune for me. He is pretty knowledgeable.
Old 11-08-2012, 10:53 AM   #10
JJAB
Harnalien, this is in response to your interest. The tune of the 1982 Blazer went awesome, aside from one glitch. It's somewhat comical now, at the end of the tune, they were running the truck so hard at times, a rocker arm bolt backed out and had to be retourqued.
Anyways, the tuner is very competent. The very first thing he did was adjust and fix the P0300 code. He also removed speed governing or rev limits. My customer was actually driving the vehicle as the tuner was sitting the passenger seat doing the tune. Long story short, it is definately to anyones advantage to have a pernonal tune done as opposed to a mail order tune. The custom basically marries the computer and it capabilities to your vehicle and its mechanical capabilities.
Old 11-08-2012, 11:29 PM   #11
harnalien
TruckincrazY
harnalien's Avatar
Awesome! Thanks for te reply. I'm really looking forward to getting mine tuned correctly! It's definitely got power, but I want it to be "right." thanks again for the update.
