![]() Join Date: May 2012
Coil over set up
Anybody have a few pics of a rear end set up with coil over shocks instead of coil springs.Thinking about running with Porterbuilt tubular trailing arms and using a coil over shock set up on my 66 step side.Would like to have it as low as i can go, but static drop instead of bags.Truck should see some track time and i think this would work well street or strip.Thoughts?
Go Fast and Have Fun.!! My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185 |
Re: Coil over set up
I should have them in my build thread and my son's build thread.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Where is Semmes?
Just little west of Mobile, L.a. as we call it (Lower Alabama)!!
Go Fast and Have Fun.!! My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185 Last edited by contagious102; 11-17-2012 at 04:20 PM. |
I am doing something similar. Its a modified Porterbuilt trailing arm . The chassis guy will make the upper shock crossmember , and I have Nates C-Notch. I think the shocks will mount on the trailing arm themselves instead of a lower bar between the trailing arms. I still have to take the stock rear suspension out , and mock up what I switching to. Next weekend I should have a better idea. It will be a bolt in U bolt rear end with some additional support to try to eliminate stress on the U-bolt itself. I may go with a bigger heim or bushing in the front also. The shock that I am using is the longest Koni that Lamb builds I think its 17". I have pics of the trailing arms with out the top bar . The black rear end is kind of the same idea with the upper bar.
Boosted Member
I modified my porterbuilt arms to mount coilovers to them.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Looks nice,thinking the the same setup with porterbuilt cross member and arms.Need to keep the coil overs inside the frame rails to get max tire size.!!
#8 | |
Boosted Member
![]() There's more room since the frame doesn't kick out like on a 2wd. Still a good amount of tire clearance. Unless you're tubbing it I guess... Mine is being built more for going fast, AND turning, so this is the setup I chose. This is how it looked using the porterbuilt mounts. Probably how I would have left it if I was building a straight-line truck. I'm willing to part with the upper porterbuilt bar if anyone is interested. It interlocks real nice with their c-notch. ![]() ![]()
Thats nice ,looks good.
