63 k10 power brake booster
I am wondering if anyone has info on what conversion for 1963 K10 drum drum power brake booster and master cylinder would work best. Motor is a pretty much stock 350. Which kit did you use.
1971 C20 350sbc mild cam Daily driver |
![]() ![]() ![]() Join Date: Jan 2018
Re: 63 k10 power brake booster
You can use the booster bracket made by member Captainfab: https://67-72chevytrucks.com/vboard/...d.php?t=339081
For the master, I'm not exactly sure what works best on the 4wd trucks, but maybe a dual master from a 67-70 4wd would work?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
60-66 Nut
Thank you Christian
![]() With one of my booster brackets I would recommend a '67-'70 booster and master cylinder for a drum/drum braking system.
Captn does he have to get a different brake push rod? or just your bracket and a booster?..Thanks!
