Old 11-11-2012, 11:10 PM   #1
Major_Tom321
Major_Tom321's Avatar
Custom under bed Fuel cell ?'s
Has anyone made their own under bed Fuel cell for their stepside? I am looking into making one like the ones on summit. Does anyone have any dimensions of their under bed Fuel cell?
Lance,
2011 Subaru WRX, Hatch- Daily
1972 C10- Project
Major_Tom321 is offline   Reply With Quote
Old 11-11-2012, 11:21 PM   #2
SHANE 73Z
Re: Custom under bed Fuel cell ?'s
Lance,
Dont know how much trouble you are wiling to go to, but I used an Aeromotive 20 gallon cell. 24"x20"x10" deep.
It definately wasnt a drop in affair, but I used Early Classics rear x-member that goes in flush with the end of the frame rails. I had to build a flange for the cell and then a frame to mount it to the frame rails. I also had to remove some of the lower flange on the angled x-member behind the rear axle.
A slightly smaller cell would have been easier & it also hangs pretty low. I would have gone another route if I didnt already have the cell from another project.
Do some searching here, there is a member that builds a nice cell that addresses most of the issues I ran into.
Hope this helps,
Shane
SHANE 73Z is offline   Reply With Quote
Old 11-11-2012, 11:41 PM   #3
Davemotohead
Davemotohead's Avatar
I just mounted a 40 Gal suburban tank under the bed of my 71 4x4 long bed,,was not that much trouble as I cut all the cross members out of the Suburb and mounted them where the stock spare tire mounts,,turned out nice and now have 40 gallons to feed the Big block monster,,there is a thread going with video's I posted.
Davemotohead is offline   Reply With Quote
Old 11-11-2012, 11:57 PM   #4
Critter
Future TOTM Winner
Critter's Avatar
I'm in the planning stages of doing exactly that. Like Shane mentioned, mine will be basically 24"x"20"x10". I will have a rear sump with -8AN fittings so I can hook up to an external fuel pump. Also going to install either a fuel door or maybe the marker light filler modification.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 11-12-2012, 12:40 AM   #5
Major_Tom321
Thanks guys,
I am just trying to weigh my options of wether I should shell out the money for a pre made one or make one.
Critter, I am thinking of doing something similar to you and Shane, I am just trying to figure out the exact configuration I want to go with.
Lance,
1972 C10- Project
Old 11-12-2012, 08:15 AM   #6
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Not exactly under bed but _ _ _
I finally got this set-up plumbed and working this weekend:
http://67-72chevytrucks.com/vboard/s...d.php?t=547782
TobyArnot is offline   Reply With Quote
Old 11-12-2012, 09:38 AM   #7
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Why would you need a fuel cell instead of a tank?
Tom Vogel is offline   Reply With Quote
Old 11-12-2012, 11:55 AM   #8
DorianB
DorianB's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=448431
This works.. although I don't really like how far it sits down to be able to have the fill tube through the license plate.
I am modifying it to use a side fill through the side reflector.
http://67-72chevytrucks.com/vboard/s...ad.php?t=77104
In my opinion, it works best to have the seat out so you have room to flop your body around while standing on your head. -ashx2
DorianB is offline   Reply With Quote
Old 11-12-2012, 12:04 PM   #9
SHANE 73Z
Tom,
I suspect we are getting into semantics here. I would actually call what I used an aluminum tank. A true fuel cell will at most basic at least have a safety bladder inside of it.
My reasoning was based on my needs for the tank. I can do some mild fabrication so starting with something close was my best option. I also wanted to move the tank from the cab as the stocker was leaking. I also wanted something that had an electric in-tank pump for the EFI I will be running.
Shane
Old 11-15-2012, 02:07 PM   #10
csfields
csfields's Avatar
Here is the aluminum fuel tank I am putting in my 71 SWB
Thanks,
Casey
71 Chevy C-10 SWB 350/400 PS, PB
The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045
The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699
csfields is offline   Reply With Quote
