![]() Join Date: Sep 2012
Any comments/suggestion on applying CLR to paint?
Thinking about putting CLR on my truck, any suggestions
Posted via Mobile Device |
Re: Any comments/suggestion on applying CLR to paint?
Excuse me if I'm showing my ignorance, but are you talking about calcium/lime/rust remover? I've used it on automotive glass, but never on paint. Are you trying to get rid of hard water spots? If so, I use a very diluted solution in water and rinse well.
20' Daredevil (Ret)
![]() Join Date: May 2003
Not saying it can't be done, but the directions printed on the bottle say do not use on painted metal.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Check the paint and body section.There is a thread that covers the subject.
This apart of preserving or enhancing a patina look, correct?
Junior Member
He is wanting to use it to lift the surface rust. The original paint/primer often times lies below the surface rust.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
The Older Generation
![]() Join Date: Oct 2009
yes, it's not an uncommon "trick" and the results can be pretty cool. It is, however, really only for a patina truck only, as alluded to above. If your truck is shiny, do not use this to "enhance" it.
used it on my gto the white paint is realy thin (was rust tinted)but still has a good shine i mixed it 1to1 with water realy cleaned it up nice and didnt hurt the shine
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
My red paint is faded and flaking off in some spots with a teal blue underneath... Was thinking about using the scotch brite pad with CLR to create a more worn look...thanks for the thread links, going to check them out
