Old 11-26-2012, 04:59 PM   #1
t2tone
1970 c10 master cylinder issue
does any one know if there is a different brake booster/master cylinder set up i could use other than the original one that sticks out into the engine compartment.I was thinking of a chevelle or camaro etc. some thing that will hug the firewall more....thanks
t2tone is offline   Reply With Quote
Old 11-26-2012, 05:15 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 1970 c10 master cylinder issue
Do you have drum brakes or disc brakes?
Keith
Convert to disc brakes.
Old 11-28-2012, 03:13 PM   #3
t2tone
disc front drum rear
Old 11-28-2012, 03:30 PM   #4
lolife99
lolife99's Avatar
I like using the new style M/C from Wilwood.
http://www.wilwood.com/MasterCylinde...rname=Aluminum Tandem Master Cylinder
Otherwise I would recommend any aluminum aftermarket M/C.
I'll never use a cast iron version again.
You can't keep them from rusting.
http://www.performanceonline.com/Dis...h-Performance/
Keith
