Old 01-29-2013, 03:57 PM   #1
dca1983
05 Yukon instrument cluser lights
I have a 2005 GMC Yukon. The instrument cluster lights are out. The digital lighting (odometer/transmission) works. Cig. lighters, all other interior/exterior lights work, but light behind gauges and a/c buttons is out. The dimmer switch seems to be working properly as dome lights come on and the digital read off dims and brightens. All signs point to a fuse, but I can't find it. Consulted owner's manual to try to find the correct fuse. Pulled two fuses (including one labeled for instrument panel cluster/driver information center), both were good.
dca1983 is offline   Reply With Quote
Old 01-29-2013, 06:53 PM   #2
truckdude239
truckdude239's Avatar
Re: 05 Yukon instrument cluser lights
the lights are burned out tis common but they are soldiered to the board
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 01-30-2013, 09:48 AM   #3
dca1983
Found that one of the truck body control module fuses was bad. When I put new fuses in, they pop right away. So there is a short somewhere.
