Old 12-04-2012, 05:17 PM   #1
Wrenchbender Ret
Grounds
Make sure your ground cables/straps are all hooked up. I put my new Goodwrench 350 engine in my 56. I went to start it & it just grunted & turn slow. I looked under the hood & the oil pressure tube was glowing red hot.
Wrenchbender Ret is offline   Reply With Quote
Old 12-04-2012, 06:08 PM   #2
mr48chev
mr48chev's Avatar
Re: Grounds
Back in the mid 70's I replaced a lot of Pontiac Grand Prix floor shift cables because someone had changed the valve cover gaskets and didn't reattach the ground straps from the firewall to the valve cover bolts on a number of cars. The cable would weld it's self to the housing and not move.
make sure you have clean bare metal under the ground straps on the block or the other end of the cable too. Our collective penchant for painting everything up nice and pretty bites us a lot of times when we insulate things with paint.
My ongoing truck projects:
Old 12-05-2012, 04:13 PM   #3
_Ogre
_Ogre's Avatar
Re: Grounds
ouch, luckily it didn't let the smoke out
had a 70s ford, every time i pushed the clutch in the headlights turned off
new ground cable fixed that too.
my 58 has a stud under the cab on the frame, ground cable from stud to: battery, body, motor and stereo.
shop air compressor timer
