Old 10-20-2012, 10:32 AM   #1
lbrowne
3 spd 86 shifts 1-2 fine, wants to stop when it shifts to third.
Happened this morning when it was taking a little timbit hockey player to 6am practice. Wasn't going fast at all, there was a hard sounding shift when going to third gear and if you give throttle it just revs, but if you let off the gas completely it really tries to stop like you're gearing down in first or got the brakes on.
No the handbrake ain't on lol
If I manually put it in first or second she drives fine. Tries to hit third and she wants to stop.
Torque converter? High speed lock up? Or the transmission itself?
lbrowne is offline   Reply With Quote
Old 10-21-2012, 11:33 AM   #2
lbrowne
Re: 3 spd 86 shifts 1-2 fine, wants to stop when it shifts to third.
No one?
Old 10-21-2012, 11:40 AM   #3
ont_guy_38
ont_guy_38's Avatar
If clinebarger doesn't chime in shortly you could pm him , He is the tranny guru on this site.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 10-21-2012, 12:05 PM   #4
notyo_cheez
Lightbulb Re: 3 spd 86 shifts 1-2 fine, wants to stop when it shifts to third.
Check simple and cheap first. Check your vacuum line to the modulator for connection/leaks.
Adjust the TV cable, with engine off slide up clip open throttle wide, snap clip down and return.
notyo_cheez is offline   Reply With Quote
Old 10-22-2012, 07:40 PM   #5
clinebarger
What transmission? TH350 or TH400?
I would check the shift linkage first.
clinebarger is offline   Reply With Quote
Old 10-23-2012, 09:33 AM   #6
lbrowne
I feel ashamed that I don't know, other than it's a 3speed and apparently a heavier duty trans? Apparently my 2wd truck is optioned out to have a snow plow - according to the glove box codes.
We got dumped on by snow last night, so it might not be till the weekend till I confirm.
If the shift linkage was broke, wouldn't that affect 1-2 shifts as well?
Old 10-28-2012, 06:32 PM   #7
lbrowne
Fluid is good, lots of it and it's still red. A bit darker than fresh but not black.
I thought for sure the trans code would be on the pan but it just says Hydramatic Div of GMC on it. I thought I seen it somewhere but it's pretty dirty out there now.
Can I get it from looking up the codes on the glove box door?
Old 10-28-2012, 07:31 PM   #8
clinebarger
Check adjustment, If the detent is between D2 & D3 it can cause wierd issues.
M40....TH400/TH375
M33....TH350/TH350C
With HydraMatic on the pan....Most likely a TH400, HydraMatic didnt design the TH350, Chevy & Buick divisions did.
Pan ID chart....
Old 10-28-2012, 07:35 PM   #9
Car'n'Guitars
Car'n'Guitars's Avatar
This should help you determine.
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 10-28-2012, 08:05 PM   #10
lbrowne
TH400 by the looks of it.
Old 01-02-2013, 09:47 PM   #11
lbrowne
I checked the fluid last week after the truck had been running for a while, it's at the proper levels.
Took it for a boot and it just doesn't want to grab that 3rd gear. Almost like a lockup converter or something is toast. Next is to haul her in and check the linkages.
