Old 12-11-2010, 09:43 PM   #1
hsdropout
'59 1/2 ton Apache - Thrust Bearings
Anybody know if the thrust bearing replacement pieces go back together dry? or should a layer of grease be applied? I am assuming it eventually gets grease through the king pin zerks.
I have the originals so I can go back and see how the parts are layered however the kit came with 4 ultra thin shims, not sure where they are to go. There is also a fairly thick spacer (3/16", not in photo), not sure if it might be for earlier models? There is only room between steering knuckles for axle and thrust bearing
Thanks.
hsdropout is offline   Reply With Quote
