Old 01-16-2013, 10:53 PM   #1
savatreatabvr
savatreatabvr's Avatar
Where did my throttle response go?
A while back I posted and boasted about my Quadrajet to Edelbrock 1407 swap! I said I had much better throttle response and gas mileage, after bolting down the 1407 my fan belts would actually squeal when I hit the gas, never did that with the Quadrajet, no I didn't spill gas or oil on them so I guess the power steering pump or alternator would have to catch up with the crank when revved up! That was great but after a few weeks it gradually stopped being that responsive and kinda feels like the old Quadrajet again! Any ideas why?
savatreatabvr is offline   Reply With Quote
Old 01-16-2013, 11:12 PM   #2
GM-power
GM-power's Avatar
Re: Where did my throttle response go?
Did you just bolt it on and go? Probably needs to be tuned.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 01-16-2013, 11:24 PM   #3
savatreatabvr
Got it from a guy on Craigslist who said it had been sitting on a shelf for 4 years, I said what the heck and took a chance, bolted it on and it ran great! So this situation is kinda like when you meet a hot new girl then a few weeks later you see her without her makeup on, lol!
Old 01-16-2013, 11:31 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
That's edelbrock for yah
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-17-2013, 12:08 AM   #5
savatreatabvr
Ahhhhhhh, you got me INSIDIOUS '86!
Old 01-17-2013, 12:26 AM   #6
cmyc5575
So, Is this thing just needing to be tuned or can some one else chime in?
cmyc5575 is offline   Reply With Quote
Old 01-17-2013, 06:32 AM   #7
donut
donut's Avatar
Maybe,
Couple things could have happened. Vacuum line could be loose or leaking, timing could have drifted out, eliminate the simple stuff first. After 4 yrs of sitting, crud in the carb may have broke loose and be clogging something.
After everything else, then seriously consider tuning.
These are just my opinions, I personally haven't used the Edelbrock carbs, though in the past Carter AFB and AVS did end up on my engines. (IMO, Carter is Edelbrock minus chrome and sticker)
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 01-17-2013, 09:46 AM   #8
king-918
king-918's Avatar
Originally Posted by donut View Post
Maybe,
Agreed, 4 years it could require a little love. I have ran that carb with zero problems
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 01-17-2013, 10:28 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
lmao
sometimes you get lucky
time to help her with some new make up!
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-17-2013, 10:39 AM   #10
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
x2 vote on crud inside. I got a "never ran" 1406 off Craigslist (good deal anyway) and I bolted it it, it lead extremely bad, in fact people advised me to throw it away cause it was a "firebomb" lol. (this was the internal leaking after killing the engine https://www.youtube.com/watch?v=5tbfjPNZLAw) It leaked a lot outside too.
All of this was because of dirt that had been able to fall inside of everything. I just took it apart and blew out all of the lines and re-adjusted the floats. Ran like a champ afterwords until the engine took a dump.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 01-17-2013, 11:22 AM   #11
Damon23
Damon23's Avatar
Carbs don't sit well. I've heard edelbrock is bad about accelerator pump issues. Clean it, tune and go from there
Damon23 is offline   Reply With Quote
Old 01-17-2013, 11:26 AM   #12
Redcap
I'll second cleaning it out. I have quite a bit of Edelbrock experience and have encountered the same thing a couple of times. Tear it down (easy) and give it a bath in a solvent tank, then use compressed air to blow out all the passages.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 01-17-2013, 01:16 PM   #13
SSC's76
No No
SSC's76's Avatar
in my defence I was drunk for 2 weeks lol.
its possible you just need to rebuild it gaskets could have rotted or the accelerator pump. did you add an in line filter when you shaped over carbs? could have some junk from the tank now sitting at the bottom of the bowl if you dident
Posted from 67-72chevytrucks.com App for Android
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 01-17-2013, 01:40 PM   #14
88Jimmy4x4
88Jimmy4x4's Avatar
could be crud in your gas tank clogged the qjet, new carb was clean and now is clogged from gas tank crud....I woud clean both myself
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 01-17-2013, 02:17 PM   #15
INSIDIOUS '86
Well if the accel pump sits and does go bad they have a habit of leaking out the top
Also the crud can be valid but idk about a carb raining dust inside lol
So maybe it's the same and your belts just don't squeal?
Or it had a small leak somewhere and it was lean and now that its sealed its rich.
Old 01-17-2013, 06:55 PM   #16
GM-power
GM-power's Avatar
I agree with cleaning it out. Didn't know it sat for so long. Just a Q but did you keep the q-jet?
Old 01-19-2013, 02:57 PM   #17
savatreatabvr
Yes I still have the Q-jet. I've had good luck with Q-jets in the past, they've never given me major problems! I just have to get it through my thick head that my 454 is high mileage and I'm not going to get the performance results out of it that I expect so I'll clean out the Edelbrock and rebuild the Q-jet and hold a little performance comparison.
Old 01-19-2013, 03:02 PM   #18
savatreatabvr
I watched your link and mine does the same thing, is time to give it a bath!
