Intermediate Shaft boot
Hello.
I've been searching and searching and cannot locate a source to purchase a new intermediate shaft boot kit for my 1980 K20. I found info on this forum suggesting that the Jeep kit works but it is a bit small (boot diameter) and a little different. There was not clamp included either. Does anyone know of a source for these? Thank you, Lawrence F. ![]() |
Re: Intermediate Shaft boot
Should be the same for all GM columns check with NPD OPGI or Inline Tube you may need to look at Car catalogs to find it.
Nate
Current Project: 1990 V3500 CC dually. |
I tried to find one and had no luck. I tried a Chevy dealer and they told me it was discontinued for at least the last 10 years.
TJ 76 gmc 1500 swb patina finish Dropped 4/5, 350/4 speed 80 Chevy c10 lwb 305/350 |
This one matches the one on my truck but the ad says it's for 64-79 Buick (and others). So, someone must have swapped an intermediate shaft from a different GM vehicle into my truck. I don't know.
http://www.ebay.com/itm/64-79-Steeri...-/190826097281 ![]() ![]() |
I heard that early chavelles used the same Shafts but could never confirm. I also saw someone one here use a jeep boot. Not sure what year.
TJ 76 gmc 1500 swb patina finish Dropped 4/5, 350/4 speed 80 Chevy c10 lwb 305/350 Last edited by tommy217xxx; 03-30-2016 at 08:42 PM. |
Yeah, the eBay site says it fits Chevelles. I'll let you all know what I find out when it arrives.
It doesn't come with the clamp (goes on the part of boot protruding inward) so I'm going to zip tie it. --Lawrence F. |
http://bowtieguy.proboards.com/threa...r-repair-renew
This is what it looks like pop out upper housing. 73-90 should work I have not found any yet. but I have used a good used one if its not ripped/ missing chunk or split should be ok Do not forget to re-grease the cover ( using needle grease tip from the top ) This center hole to put grease in. you want it about between 1/2 to 3/4 full . It looks like it may be the one. hard to tell the truck one stretches a bit when it full of grease the rubber seal should just be a little pushed out @ bottom it should not stick out to far pass the cover. ( the center area of the seal is ok as long as it not super hard ( stuffed with grease down there)
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 04-03-2016 at 01:21 PM. |
Pontiac1976 -- thanks for the pics and info!
The new boot arrived yesterday. It is the correct shape but once again the diameter of the boot's base is smaller than the coupler opening -- so much so that grease would seep out near the areas the boot doesn't cover. The original boot fits snugly in the coupler opening -- no slop whatsoever. What is the deal? Could my couple have come from a different manufacturer? (ie, not GM original part?) tommy217xxx, I think this confirms that the Chevelle part will not fit our trucks. I may need to improvise using one of the incorrectly sized boots. --Lawrence F. Last edited by swanthog; 04-06-2016 at 09:57 AM. Reason: add detail |
http://www.4wd.com/Jeep-Brakes-and-S...er_PQ=Omix-Ada
This might work not OEM. This may need clamp lower side hold it in place. It does look longer then the one you got, if upper round part is same size might be good replacement for dry out or ripped seals. If you can get them to give you sizes. Let us know.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 04-10-2016 at 11:32 AM. |
Moderator
![]() Join Date: Oct 2008
Put in a, Jeep XJ or Borgeson, U-Joint steering shaft.
https://www.google.com/search?q=XJ+steering+shaft+Chevy
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Any updates on where to find this boot?
1970 2WD Blazer 454 1972 C-10 Extended Cab 350 SBC |
Moderator
The Saginaw steering boxes and shafts were used on a bunch of GM, Chrysler, and AMC vehicles.
Suppliers engage in keyword spamming. Jeep, Chevelle, Impala, ... are likely not the only vehicles these boots fit. They are popular models and nameplates so they prominently feature them in their descriptions to drive search engine traffic. If the "Chevelle" part fit one CK truck it's likely it will fit most of em.
![]() Join Date: Jun 2012
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
Remember to prioritize your battles. After spending hours researching that boot, and ordering several wrong ones and returning them, you could have just bought a new Jeep Cherokee shaft instead.
If you're going for a perfect restoration, then by all means, chase down the correct boot. But if a good driving truck that looks neat is your primary concern, then do the Jeep shaft upgrade to eliminate the rag joint, and solve the boot problem at the same time.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
#15 |
Or you could go to the wrecking yard and find a fullsize savana van around 96 97 and you will find the steering shaft all incased in a boot cut that off and remove whole shaft for its a direct fit other than a notch at top by the cinch bolt and has u-joints instead of rags. I covered this on my thread about half way through.
100:1 low gear! |
#16 | |
