Old 02-06-2013, 08:50 PM   #1
Ziegelsteinfaust
SRW to DRW
I got a C20, and I really want a dually. Every once in awhile I see a slammed obs rclb blue dually slammed on 16 polished alcoa's. Which to me is just WOW. I won't just buy a dually because I have a 74 which where I live is pre-smog, and I never seen a rc dually pre 77 when I was searching. Plus I will have fixed up my truck to my specs, and I won't want to start again.
I have seen online the drw axles are wider the srw axle, and they use the wms measurement. What does wms mean? I will use rear spacers so I can upgrade the axle I have now to suit my plans, and not have to replace it later. Also I can set the rims right where I want them for the perfect stance.
Also C20, and dually A arms are the same. It is just the spindles where everything gets different? I wouldn't mind rebuilding my front suspension first, and then convert it later.
I am looking to buy a front cross member here in a few months to start my gathering of parts, and rebuild of my front suspension. Plus I really don't want to start buying parts till I figure out which way I want to take my build. Right now I am stuck between off road tires, race suspension truck, and slammed dually for cruising.
Ziegelsteinfaust is offline   Reply With Quote
Old 02-06-2013, 09:45 PM   #2
SCOTI
SCOTI's Avatar
Re: SRW to DRW
WMS can stand for 'wheel mounting surface' & is commonly used when indicating where/how a rear end was measured.
C20 & C30 spindles are the same from what I could see when I was looking for C30 spindles. The difference is the rotors: SRW (single rear wheel) or DRW (dual rear wheel) 8-lug.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-07-2013, 01:01 AM   #3
andrewmp6
Re: SRW to DRW
See how cheap you can find a dually parts truck for.A junkyard will nickle and dime you to death find a whole truck for 500ish and buy it.Take off all the dually parts and anything else you can use on your truck then scrap the truck out.
Old 02-07-2013, 01:22 PM   #4
comegetsome2003
comegetsome2003's Avatar
Re: SRW to DRW
Its not a hard swap.....like mentioned above the control arms are the same as are the spindles and brake calipers....just need to change out the the rotor/hub assembly.....or another option is to go to a junkyard and get a front dually adaptor that comes on the 01 up duallys....they are bolt on and very easy to remove/install
Your SRW is right at 8 inches shorter that a DRW....you will need to swap out the whole rear end unless you wanna run semi wheels....my dually has a SRW axle in it with 4 semis out back and its perfect for gettin the tires tucked under the fenders....after that bolt on your rear fenders and your swap is done
1991 Square CCLB Dually...laid out on 22s with an old noisy 12 valve
comegetsome2003 is offline   Reply With Quote
Old 02-07-2013, 01:38 PM   #5
Ziegelsteinfaust
Re: SRW to DRW
Thank you guys. Sometimes there is just to much info to go through.
Old 02-07-2013, 01:46 PM   #6
Ziegelsteinfaust
Re: SRW to DRW
I see them once in awhile, but unfortunately there the newer models. While the suspension swaps over, the few body pieces I need don't. Plus I really don't have room at my place for another truck right now, and a space to safely work on it. So I am not sure the hassle is worth it unless I find the years I can use on my truck.
If my project truck was on the road, and my soon to be ex-wifes VW van was gone it would be a whole other story.
Other then that it would be a great deal I feel picking, and choosing the exact parts I want maybe cheaper in the end.
