side mount gas tank 60-66 chevy truck
Has anyone done a side mount gas tank install. How many gallons do they hold. I have seen some retrofit in old trucks. I would like to move my tank out of the cab but look at options other than at the rear of the truck between the frame rails. I had thoughts about mounting a spare tire at the rear underside of the truck.
Thanks Jeff. |
![]() Join Date: Jan 2011
Re: side mount gas tank 60-66 chevy truck
The way the cab is done and as little room as there is under the bed floor I would expect the tanks would be small. i had trouble getting the air tank under mine.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
I looked into this alot and couldn't find anything that would work. Maybe build a custom tank? If you decide to do something different the gas tank from a 68-72 A body mounted in the rear works great.
My truck has a small side tank on the drivers side that fills from the wheel well. I am using that same location to put my fuel cell and will do a proper filler. The one in there now isn't very big and has no sender. I've never used it since it seems to be solid rust.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#5 | |
At rear of truck, between frame rails is safest place for it.... why do you want to sit on top of 20 gal of BOOM, and try not to get into a wreck? All that for a spare tire? Thats what AAA is for...
1960 C-10 2000 Dakota R/T 1966 Fury I 2dr post 1984 Big Bronco 2002 Durango SLT (Bride's Ride) |
