Old 08-07-2015, 01:13 PM   #1
schoolbuilder
71 K20 vs. 73 K20 frame dimensions
Hello, all. Does anyone out there have prints on these frames? I've been told they "should" be the same, but I'd like to confirm before I order a '73 gooseneck hitch for my '71 K20 Cheyenne. All the hitch manufacturers only list down to 73 for compatibility. Thank you.
schoolbuilder is offline   Reply With Quote
Old 08-09-2015, 09:35 AM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: 71 K20 vs. 73 K20 frame dimensions
Beautiful truck. I believe the 73 frame kicks up more at the rear but I believe they are the same width.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 08-09-2015, 09:40 AM   #3
hugger6933
I'm thinking that is is gonna work. If your still not sure why not have a welding shop fab you one up. I've had some homemade ones on some of the trucks I've had or junked out and they looked pretty good. Jim
hugger6933 is offline   Reply With Quote
Old 08-09-2015, 12:16 PM   #4
Jeff's bowtie's
I think the major difference in the two frames is only under the cab 67-72 being flat and 73-87 curving up to allow room for the underside gas tanks but the part that goes over the rear axle is the same
Jeff's bowtie's is offline   Reply With Quote
Old 08-09-2015, 07:16 PM   #5
jocko
jocko's Avatar
Probably not relevant to your hitch question, but, 67-72 lwb: wb=127" ... 73-87 lwb: wb=131.5"
Old 08-10-2015, 09:07 AM   #6
schoolbuilder
Thanks, guys. It does seem my frame measures the same as a '73. 34" outside-to-outside of frame rails over the axel. So it appears a hitch spec'd for a '73 will fit this particular '71. I'll be pulling my 32' 5th wheel camper that I used to pull with an '08 GMC dually. The trailer exceeds the posted GVW for this '71 truck, but I'm confident that with the tow package equipment I have and conservative driving it will handle it. It has the tranny cooler, what appears to be a 1T rear axel (8 bolt wheels) and a healthy stack of helper springs. I'll report back on how it goes.
