Old 02-13-2013, 05:08 PM   #1
hilljob26
hilljob26's Avatar
need a pic of exhaust manifold
i am needing to change my exhaust manifolds from the factory truck ones to something smaller, like maybe the trailblazer ones,,does anyone have a pic of the trailblazer ones with measurements so i can see if they will fit,my motor might be sitting just a hair low in the frameand i need to see if i need to raise it up, or if those will work,,mainly need how tall, how widefrom the flange.thanx
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 02-13-2013, 09:01 PM   #2
mrhurt73
Re: need a pic of exhaust manifold
here is a whole thread just for trailblazer manifolds
http://67-72chevytrucks.com/vboard/s...d.php?t=530623
if this doesnt get you what you want let me know and i can measure any specifics for ya.
My Projects-
http://67-72chevytrucks.com/vboard/s...d.php?t=557301
Quest for Hot Rod Power Tour 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=543735
my 85 GMC 2wd to 4wd conversion for the wife.
mrhurt73 is offline   Reply With Quote
Old 02-13-2013, 09:22 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I don't have measurements, but here are some shots I have of the TBSS manifolds, off and on my 66/lq4.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-13-2013, 09:57 PM   #4
JJH Jimmy
JJH Jimmy's Avatar
They will fit. I have been following your build and I know that you are using the AA adapter. I am doing the same thing and I kept my TC in the stock position and my engine is at 5 degrees. The flange on the passenger side is close to the frame rail but they fit with no trimming. I will try to post some pictures tomorrow.
JJH Jimmy is offline   Reply With Quote
Old 02-13-2013, 11:05 PM   #5
hilljob26
hilljob26's Avatar
i agree, and after looking at the pics im sure they will,,and to buy them for 125 shipped is a killer deal right now since just the right side is going for that on ebay
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 02-14-2013, 02:41 AM   #6
mcmlxix
Collector of Projects
mcmlxix's Avatar
I have a set of 2010 Camaro manifolds on my K5...
2010 Camaro manifold... Camaro on the left, Sierra on the right...
Its 7" from the last manifold bolt on the head straight down to the flat gasket surface of the flange.
It sticks out 5.25" from the side of the block at its widest point. (Opposte of where the starter would attach.)
Rich
1972 K5 Blazer CST Click HERE
Old 02-14-2013, 11:19 AM   #7
JJH Jimmy
JJH Jimmy's Avatar
Here are the pictures. I got my TB SS manifolds and heat shields from GM parts Direct for about $180.00 to my door.
Old 02-14-2013, 11:26 AM   #8
Hart_Rod
Hart_Rod's Avatar
I've got a set of exhaust manifolds off a 2013 Camaro SS with only 135 miles. If they will work for you, shoot me a PM.
Hart_Rod is offline   Reply With Quote
Old 02-14-2013, 01:30 PM   #9
hilljob26
hilljob26's Avatar
nice....you should really have a build thread, i would like to see more of your project
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 02-14-2013, 02:52 PM   #10
JMac11
JMac11's Avatar
JJH JImmy.... great looking exhaust.... Where did you get the flanges for the Tbss manifolds???
JMac11 is offline   Reply With Quote
Old 02-14-2013, 03:36 PM   #11
JJH Jimmy
JJH Jimmy's Avatar
When i got my engine it came with the truck manifolds with the flanges and the chunk of pipe with the o2 bungs. I cut them off and welded them to the stainless tubing using 309 wire.
Old 02-14-2013, 03:42 PM   #12
JJH Jimmy
JJH Jimmy's Avatar
I know. I have been meaning to for some time. I just need to spend an afternoon on the computer instead of in the barn!
Old 02-14-2013, 07:03 PM   #13
JMac11
JMac11's Avatar
Great.... how close is the right side, lloks close but may be the camera angle
Old 02-14-2013, 08:11 PM   #14
JJH Jimmy
JJH Jimmy's Avatar
Real close. About a 1/4".
