Old 02-11-2007, 12:07 PM   #1
plagee
plagee's Avatar
Trans control relay needed?
What in the world does the trans control relay do? I have the part numnber of 3990842 (littlefuse). It has a seperate harness that connects to the main harness above the hood hinge. There is also what appears to be another relay next to it that is connected to the same harness, the ony thing the wiring diagram lists is: RELAY ASM CONT SW. The harness that I have in the truck has 4 wires that have been butchered by the previous owner, and do not connect to anything. Any info would help and would be much appreciated.
plagee is offline   Reply With Quote
Old 02-11-2007, 12:14 PM   #2
MT1972cheyenne
MT1972cheyenne's Avatar
Re: Trans control relay needed?
This is an early emission control system that is almost always disabled. I bet if you look down on the passenger side of your transmission just above the pan lip, you will find that the transmission switch is either unplugged or gone.
MT1972cheyenne is offline   Reply With Quote
Old 02-11-2007, 12:39 PM   #3
plagee
plagee's Avatar
Nope, nothing on the trans. I am guessing that this is no longer needed.
Old 02-13-2013, 12:54 PM   #4
Groyd
Groyd's Avatar
Had to save an old thread.
Is the relay on the left the emission control?
What is the relay on the right?
1951 Chevy 3100/S-10:
http://67-72chevytrucks.com/vboard/s...d.php?t=406072
1957 Chevy 3200
1971 2WD Blazer - Sold
Groyd is offline   Reply With Quote
