Old 02-12-2013, 11:13 PM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Aux battery harness install: Where is hole placed in firewall???
Should have asked before painting but where does the harness for the aux battery enter the firewall? I assume a new hole needs to be drilled but where? Any detailed pics of a factory install would be hugely appreciated!!!! Thanks, Pete
Old 02-13-2013, 02:51 PM   #2
Sideways
Sideways's Avatar
Re: Aux battery harness install: Where is hole placed in firewall???
I went out and took a picture this morning,is this the shot your looking for (red wire)?
Sideways is offline   Reply With Quote
Old 02-13-2013, 03:57 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thank you for the pic!!!
Old 02-13-2013, 04:24 PM   #4
Sideways
Sideways's Avatar
Glad to help.
Old 02-13-2013, 04:34 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Looks like it would be centered in the firewall dimple just below where the tach harness hole would go. Good to know for anyone adding one or both of these options. Pete
Old 02-13-2013, 04:47 PM   #6
Sideways
Sideways's Avatar
Looks like I will be drilling a hole for my tach harness!
Old 02-13-2013, 05:44 PM   #7
vidman
vidman's Avatar
Great info there..Now another question is where does the harness connect to inside the cab?
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 02-13-2013, 06:07 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's a schematic of the harness if that helps....
Old 02-13-2013, 06:19 PM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Pic borrowed from another member of the dimples I mentioned with a factory TACH hole. Looks like the hole for the aux battery is centered in the dimple that is second from the bottom whereas the tach hole is centered in the dimple third from the bottom.
Old 02-13-2013, 08:54 PM   #10
Tuff Gong
Tuff Gong's Avatar
What the best way to drill a clean hole for these harnesses?
Tuff Gong is offline   Reply With Quote
Old 02-13-2013, 09:19 PM   #11
vidman
vidman's Avatar
That works...Thanks Man
