transmission line factory fittings
I know these threads are a special thread (straight pipe thread?). Is there any line that I can use with the existing fittings shown below?
Posted via Mobile Device |
![]() Join Date: Jan 2009
Re: transmission line factory fittings
Do you have the original lines? Just cut them, and flare/rubber hose as necessary. Next week I'll have an extra set (4l60e) that are cut at the front of the oil pan....yours if you want them.
1949/1954 with LS swap-yeah! http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos |
#3 | |
Not sure if the 4l80 are the same size or not. No problem using the stubs. That's essentially what I'm doing, just longer. I liked using the OE lines along the pan for clean routing. I used compression fittings to tie into hard line and rubber hose to connect and allow flex at rad.
If my memory serves correctly, both lines were 3/8". I'll check tomorrow. Lmk. Posted via Mobile Device
#5 | |
Collector of Projects
I purchased 4L80e lines form GMpartsdirect. They use little clips (look like window crank retainer clips) and little black plastic caps that were already on the lines. You can also buy AN fittings that replace the factory style. They make the correct long short combo for the 4L80e....
The factory lines are long enough. I used factory lines no cutting. I think i had to bend them a tocuh with a tube bender but thats it. Now oil lines are a bit tricker. Again i used factory lines but its not as clean as i would like. My engine is set back 2 1/2 in aswell
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
meowMEOWmeowMEOW
I have a 4l80e line sitting in my spare's bucket if you need it. I upgraded to the AN versions.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Sorry for dropping off the radar for a couple of days. I just had a major productive weekend on my swap. Drove the truck into the shop. Set the front clip off. Gas tank out. Engine out. Cleaned frame rails. Set new 6.0 and 4l80e in place
![]() Anyways. I really appreciate the offers on the trans lines. I will be happy to pay shipping or whatever I owe to chev3600 or BR3W. Just let me know guys. Posted via Mobile Device |
Pm address and I'll send them out. If you can use them, cool. If not, do what you want with them. I had to switch to tbss lines because the routing is different to clear the manifolds. Stock 5.3 runs them above the starter, trailblazer is below. Lmk.
#11 | |
meowMEOWmeowMEOW
Sounds like he's got you covered but if for some reason you need this one just drop me a line, I can toss it in a documents tube or something.
