Old 01-21-2013, 12:41 PM   #1
1bad84silverado
c notches what are these?
What are c notches and what do they do? I'm looking at buying a drop kit that comes with bolt in c notches just wondering if I have to do anythibg special to truck.
1bad84silverado is offline   Reply With Quote
Old 01-21-2013, 12:48 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: c notches what are these?
They add clearance in your frame directly above the rearend's axle tube.
(to allow for more drop)
Keith
Convert to disc brakes.
Old 01-21-2013, 01:38 PM   #3
88Jimmy4x4
88Jimmy4x4's Avatar
you have to cut or "notch" your frame for that
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 01-21-2013, 11:58 PM   #4
81Scottsdale520
81Scottsdale520's Avatar
Basically this
~When In Doubt Go Lower~
81Scottsdale520 is offline   Reply With Quote
Old 01-22-2013, 12:54 AM   #5
Pop's C-10
Pop's C-10's Avatar
Originally Posted by 81Scottsdale520 View Post
Basically this
That is not a C-notch
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 01-22-2013, 01:05 AM   #6
ivorton74
ivorton74's Avatar
Basically this
that's a z'd frame...this is a c notch...
ivorton74 is offline   Reply With Quote
Old 01-22-2013, 01:16 AM   #7
Pro Performance
Pro Performance's Avatar
Here is a c-notch installed on an earlier frame.
Pro Performance is offline   Reply With Quote
Old 01-22-2013, 02:17 AM   #8
bigwheel15
bigwheel15's Avatar
his is a c notch...
That's not a z'd frame, a z'd frame is when the front of the frame just in front of the cab is cut and raised then rewelded effectively allowing the front to tuck more and the truck to sit lower. The z is in reference to the shape the frame where cut and rewelded resembles.
bigwheel15 is offline   Reply With Quote
Old 01-22-2013, 02:33 AM   #9
andrewmp6
A c notch is small its called that because the cut out looks like the letter c,Those are step notches its bigger brother.A z'd frame is a fully different animal then any kinda notch.
Old 01-22-2013, 07:48 AM   #10
lolife99
lolife99's Avatar
Basically this
That would be a "step" notch.
Keith
Old 01-22-2013, 11:54 AM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Correct answer. The first notch pictured is referred to as a "step notch" not a Z'ed frame. The small notch posted by Pro Performance is a bolt in "C-notch" which is common to most average size lowering kits.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-23-2013, 12:25 AM   #12
ivorton74
ivorton74's Avatar
oh my bad...guess I just learned something new
