Tailgates without Chains
I'm putting my bed back together & don't want to use the stock chains & hooks.
What after market or OEM parts have you guys adapted to fit your 64 - 66 fleetsides? I plan to use stainless barrel slides to secure the gate but what type of flat bars or cables work best? Was any cutting of the tailgate required? |
Registerd User
Re: Tailgates without Chains
Welcome. Check out my build thread. I got an aftermarket tailgate from mar-k. Hope you get the info you want.
That's really trick set up but at nearly $600 w/o shipping is beyond my current budget. It does look great though as does the rest of your project. You are doiing some gret work.
MAR K sells the slide barrels & chain eliminators for $150, I was hoping to find an even lower cost option. ANy ideas or pictures would be great. Thanks |
Registerd User
I've seen people use latches simular to the ones mar-k sells but made for the doors on sheds and such from the ho depo or lowes and I don't see why the linkages from a square body wouldn't work.
This is the hardware from a late model S10. I bought a wrecked tailgate for 5.00.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
502tripower,
that looks really nice and very well done. I take it that you just pull those tabs of bolts inward to get the latches to release? -W some more options to look at: http://www.wow-products.com/ products / tailgate ---- http://www.persh.org/pickup/IdeaPage.htm look under Tailgate & Beds ---- -W Last edited by Woogeroo; 02-22-2009 at 09:31 PM. |
502TriPower, that is the solution I was looking for. That cost is more in my very small ballpark.
Did you weld the MAR-K type slide bolts to the S-10 latch? Does the whole latch unbolt & slide out from the end of the tailgate? Do th cables hide in the space between the tailgate & the bed or do the cables store in the bed? Thanks, Blue666 |
#8 | ||
![]() Join Date: Oct 2006
l You want cheep? Like Jason65 said use gate latches I did mine this way
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
The previous owner on my stepside used 80' model tailgate hinges and welded seat belt loop to the tailgate and the buckle side to the bed. Really cool. I'll get some pics posted...
![]() ![]() and for the curious ones, my display shelf from lowes for $10! ![]() Last edited by austex66; 02-24-2009 at 09:15 PM. |
#11 | |
I used latches and cables from Frantsen. They have bolt on or weld on. Give them a call, real easy to get along with........
http://www.frantsen.com/chevygmc.html |
http://www.mar-k.com/Catalog/catalog.aspx
$75 from Mar-K. Latches up to you. I am taking the hidden one off and going with cam locking clam style. http://www.horkeyswoodandparts.com/page17.html They also have hidden latches and supports.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
