and a few others
53 ~ S-10 project (yup, another one)
Well, since I'm getting started now (slowly) I guess I better start posting what I'm doing.
Here's the 53 I picked up for $400 last year.... ![]() ![]() Here's my (running) S-10 standard cab longbed I got for $300.... ![]() And the 4x4 S-10 (for the rearend) I got for $100.... ![]()
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
and a few others
Re: 53 ~ S-10 project (yup, another one)
Then, a '92 dually I bought off eBay that was just right up the road from me about 50 miles. I got it for $700. It has a center-bolt TBI 350 with a 4L80E trans. It had a bad fuel pump, but it ran if you poured gas down the throttle body. Plus, I wanted the wheels/tires for my 69 one-ton dump truck....
![]() I took off the front clip and advertised it on Craigslist. I haven't sold it yet, but I'm sure it will sell as soon as the weather gets better.... ![]() Got the motor/trans/ECM/harness all out.... ![]() ![]() I plan on sending the harness out to get it re-worked.
and a few others
Got the rearend out of the 4x4....
![]() And, I took the steering column, brake/clutch pedals, master cylinder and a bunch of other stuff I can't think of right now, then off to the crusher it went.
and a few others
Got the body off the 2wd frame....
![]() Sold the 2.8 engine and 4spd and the front clip off Craigslist.... ![]() And the 2wd frame is all stripped and ready to go into the garage. Hope this isn't too many pics. I know I like lots of pics, so I always assume everyone else does too.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi Last edited by 63 & 64 Bowties; 02-08-2010 at 01:34 PM. Reason: felt like havin' a peanut butter & jelly sandwich |
Looks like a good start. Glad to see another s-10 swap.
very nice, I cant wait to see more.
Keep the pics comming
excited for more progress!
[CENTER][FONT="Arial Black"]-------------------- Joey Dubs -------------------- 2000 Dakota - Bagged, Shaved, and more 2003 Ram - Fast, and perdy 1951 GMC Stepside - All apart, like a puzzle. |
4 trucks for $1500 - thats awesome....
Looks like you literally tossed the S10 cab off the frame ![]()
1953 GMC 1/2 ton long bed Original 228 I6 with a Hydramatic Auto Tranny Project Pack Rat - http://67-72chevytrucks.com/vboard/s....php?p=3374649 ![]() |
and a few others
Looks like it, huh? Actually I used the front end loader on my tractor, but it kinda swung back and hit the uprights. Oh well.
and a few others
I'm in the process of taking the cab off. Started today. I'm gonna try to take the cab off with the doors on and the hood on too. If I can leave the hood on, I think it will make it a lot easier to line up the fenders when I put it back together since these things are so finicky about lining up.
Also, I had the idea to take measurements on the truck, hoping that will give me a better start on sitting it down on the new frame. They're not exact because some of them are from the ground up and some are measured from the door handle. Just wanted to pick something that wasn't gonna move. ![]()
#12 | |
My front clip still isn't mounted on mine, it's just sitting there. Still scratching my head as to how I want to mount it...I'd like to build legs on both sides and use bushings...but also need to be able to fit the 19x22 radiator...
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
Oh yeah I just noticed the 2+2 in the background. Nice
#14 | |
and a few others
I tried lifting the cab with the hood on today. But, holy crap is that thing front heavy with the hood on. The hoods aren't that heavy, but I guess it's because it's got that 4 foot leverage. I'm not sure if that plan's gonna work. It keeps wanting to roll forward.
#15 |
and a few others
Thanks, it's one we sold last year. My brother and I restore Stangs.
That way I have money to spend on these old trucks. ![]()
#16 |
great start the 53 looks nice.keep the pix coming.
#17 | |
Yep, half way up should do the trick. I do think it would be worth the time and effort if you could leave it bolted together....
#18 |
AD Addict
For the front heavy thing, try by running chains or straps from the front body mounts up rather than trying to lift from the roof. That way you can run short ones in the front and longer in the back so the front is lifted more.
Does that make any sense? I've never tried it, actually. I usually lift with my end loader from the front and set it on that way. Never had one with a hood still bolted on!! I started a short box swap this weekend. I guess I better start a thread myself! |
#19 |
AD Addict
I've never done a "modern" motor but found a running 350 in a 89 WT for $300. What do you guys do for wiring ECM etc?
#20 |
TBI is simple. Most of the wires you'll see run from a sensor to the ECM. You'll end up with a couple hot all the time wires (orange) and a couple of hot with ignition wires (pink/black stripe) and a few grounds. I really like s10 harnesses, mainly because they have a really cool grommet that passes through the firewall with a 2.375" hole very cleanly behind the PS head. Truck harnesses are fine too but they're quite a bit longer, which often times isn't needed.
#21 | |
and a few others
First attempt was with the wood cab-lift. I even had a ratchet strap (red strap in the pic below) that ran from the hoist to the hole in the floor where the starter button came thru. ![]() That didn't work, so I took the trans crossmember from the dually and used it as a spanner. I had a couple "I" bolts, so I drilled holes near the ends of the crossmember and attached them, then got three bolts and welded one chain link in each. One for the center of the crossmember, and one for each front body mount. Then another ratchet strap thru a hole behind the seat perch. ![]() I forgot to take pics, but it was basically leaning about the same. So, as much as I hate to do it, I think I'm gonna have to take the hood off. Leaving the hood on seemed like a good idea at the time, but I don't think it's gonna work. ![]()
#22 |
and a few others
Maybe for you
![]() I'm strictly a 1st gen kinda guy. This electronic stuff is way over my head. Plus the fact that I've got an electronic transmission, that's why I'm gonna send it out to get reworked. There's several places that will send it back to you with a new fuse panel and instructions where to hook your ign, start, fan, etc plus hook up your diagnostic plug and a wire for a check-engine light. Hey, I'm 62 years old. I have trouble hooking up a VCR !! What was that you said? What's a VCR? Oh, that's those things that were around back before DVD and Blue Ray. ![]()
#23 |
So how sturdy is that cab lift set up when you are rolling the stand away from the frame? Seems like an iffy set up, but so many guys are using it (I obviously haven't yet)
#24 | |
#25 | |
