17" Dually Wheels (Low1ton, Scoti, Lowlife99, GCncsuHD)
So the new 20" dually wheels being released by Eagle Alloys got me hot n bothered enough to where I was just about to pull the trigger on a set, but I *just can't* get over not having a suitable load rated tire. At the very least, an LT.
S I got to thinking about maybe just running a set of the 17" wheels. At least I can them run an LT, if not a full on "D" or "E" rated tire (although, I haven't found a 17" tire w/a 29" diameter in either rating yet). Three questions: 1. What is everyone running on the inside? I thought I read somewhere that a 17" Dodge steelie will work. 2. What tire size is popular in this application? 3. Anyone have any pics of a dropped square dually on 17's? |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 17" Dually Wheels (Low1ton, Scoti, Lowlife99, GCncsuHD)
The new Chevy GMC duallys have 17" wheels, but these are the new 2011-up Chevy bolt pattern.
Why Gm changed the bolt pattern is beyond me. I don't know if the new Dodge (8x6.5?) or Ford (8x200mm?) pattern is the same as the old GM pattern. Dodge 17's. http://www.ebay.com/itm/NEW-DODGE-RA...sories&vxp=mtr Ford 17's. http://www.ebay.com/itm/17-Ford-F-35...sories&vxp=mtr
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-09-2013 at 08:28 AM. |
This Dodge wheel says it's the correct 8x6.5 pattern,...
http://www.ebay.com/itm/Dodge-RAM-35...sories&vxp=mtr
#4 | |
You know how that interwebz expertise goes, but at least check it out before you buy. |
I am running Firestone destination st tires. They are staggered sizes with shorter up front taller in rear. I don't remember exact sizes I will look later but I think they are 245 in front and 255 in rear. My experience with 17" wheels is the offsets are not perfect for my 2000 gmc they either set in to far or stick out a little. The set I have currently work pretty well but they are my third set. They are ultra wheel brand. For the inside wheel it is a 17" steel gm wheel that tennessee wheel and tire machined the bore larger and the made me hubcentric rings to center them up. Works great have not had a single issue. I am going to move to the 20" wheels when they become available and I see they fit good. So I will have a nice set of 17" wheels and tires just sitting around. Let me know if you have more questions. I will throw up some pictures later.
"WIDER IS BETTER" (TRUCKS ONLY) |
To my knowledge it was because of the much higher GVWRs that the new trucks are capable of. Changing the bolt circle prevented people from putting the earlier style wheels on which are not approved for the higher loads.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
#7 | |
My current set-up consists of 16" alum outers & OE 16" inner steelies w/235-75 LT's on the front & 235-85 load rated E's on the rear. My plan was to do 17" steelies/wheels & try to get as close as possible to current sizing (29.9"F; 31.7"R). Some 245-70-17 E's in front @ 30.6" & 245-75-17 E's out back @ 31.5" are what I found easily available & load rated. I really like the Eagle's & feel the 20" diameter fits these larger trucks well. The tire size/load range concerns & possible dropped truck spacing concerns are what's holding me back.
Nitto has the Dura Grappler 275/60-20 LT 10 ply at 33"
Ok for lifted or stock height, but 33" tall tires don't work on the front of a square dually when dropped moderately or more. I'd also be worried about 275mm width on a 7.5" wheel in the rear dual app's.
