Old 03-18-2013, 10:24 PM   #1
Dylan86
Dylan86's Avatar
Quiet cab ideas
I am wanting to get my cab as quiet as possible, minimal road and wind noise, any ideas?
Dylan86 is offline   Reply With Quote
Old 03-18-2013, 10:59 PM   #2
Ziegelsteinfaust
Re: Quiet cab ideas
Dynamat or alternative.
Rhino lining if you want more rugged.
New window seals to keep noise out.
Full interior.=, and dynamat to this would be the best.
Ziegelsteinfaust is offline   Reply With Quote
Old 03-19-2013, 12:09 AM   #3
Rubble
Re: Quiet cab ideas
Even having the higher end interior trim,Silverado or Sierra Classic with full carpet will make a difference.Just got an 86 K25 with 6.2.it had SierraClassic trim,full carpet,door carpet & head liner,it's WAY quieter than my 82 K25 6.2 with just rubber floor mat.I forgot what it was like to hear the radio on a gravel road!!
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 03-19-2013, 02:16 AM   #4
dieseldawg142
dieseldawg142's Avatar
Re: Quiet cab ideas
^^^ya, those just rubber floormat trucks are way loud!
some good idea's here, you should check out SOUND DEADNER SHOWDOWN, alot of good info on quieting down trucks, i just installed peel n stik sound deadner & mass loaded vinyl in my truck. have'nt had it on the road yet, but just running it & it's unbelivable the difference. can talk in a normal tone, stereo sounds like it has another amp & sub in it. totally happy with it so far
dieseldawg142 is offline   Reply With Quote
Old 03-19-2013, 04:30 AM   #5
Remon.
Remon.'s Avatar
Re: Quiet cab ideas
Put sound deadener on the floor, firewall, backwall and in the doors. Over the sound deadener on the floor some under carpet material and you carpet. This way you should notice a big difference.
New window and door seals also helps.
Remon. is offline   Reply With Quote
Old 03-19-2013, 04:49 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Quiet cab ideas
the extra inside stuff sure helps but maybe some early inner door seals
http://67-72chevytrucks.com/vboard/s...d.php?t=571269
post 12
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
