Jim's 1966 SW BBG
I had owned this 66 3 years ago and sold it. The guy had found another truck so he called me and I luckily bought it back. It is getting so hard to find SW BBG trucks it has very little rust. My plans are to update 350 motor, automatic transmission, disc brakes , lower it and have fun .
Re: Jim's 1966 SW BBG
Put in the 3" rear lowering springs today. Had to use cutting torch on old rusty bolts. Luckily I ordered the new mounting hardware ( highly recommend) . Didn't have to undo shocks to get old springs out. Cherry picker worked well on lifting rear of frame with bed off.
Nice Score on getting this back…
![]() I'm in for the ride... ![]()
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
One foot in front of the other
![]() Join Date: Aug 2008
loooks good- interested in selling the metal radiator hose by chance?
I'm following along. Anybody wanna guess on the percent of doors cut for speakers LOL
I hate when they cut speaker holes in the doors and cut dash for a big stereo. That was the first thing I did was change drivers door out to a better one. Luckily passenger door and dash was not cut.
I'm just glad to be here!
Awsome that you got it back. New motor looks nice!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
I'll be checking in on this one.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
Replaced the rear brakes all new shoes, drums, wheel cylinders and all hardware today . Good investment .
Had to get out in 20 degree weather with snow on the ground to put new 350 motor and automatic trans in today. Lots of hooking up to do .
Here is my 2 X 4 transmission cross member till I get the right one. Its on order.
![]() Join Date: Mar 2013
Looks good! Neat to see you were able to buy it back!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Today I spent several hours adjusting drivers door hinges and latch to shut good. Also shimming fender and getting raised up. What a pain.
Decided to pull the cover plate off the heater box . Completely full of leaves and nut shells. 2nd one I have pulled that way. I decided to change heater core now instead of when it decides to leak. The new core tubes were about 1/2 inch wider that old so had to grind out the cover plate. Typical for repo parts. The 2 nuts holding the heater box to fire wall under the dash was a bear to get to.
#15 |
Great Idea. Progress is looking good.
#16 |
It will be a slick ride when your done!
#17 |
New transmission cross member was out of stock so I fabricated on today with C-channel. Cut channel and drill 4 holes saved $80.00
#18 |
Sometimes its just easier, quicker and cheaper to fab your own stuff and its made in the USA!
#19 |
Today I changed out the froze up emergency brake cables and adjusted . Got drive shaft with new u joints and yoke installed . Cleaned dirt from around U bolts that hold rear end housing. The U bolts are over have way rusted through very dangerous. More parts to order when does it end.
#20 |
AYE! That is perrty rusty....hammer should take care of it.
#21 |
Keep up the good work, looks like a great project.
1965 Short Fleet http://67-72chevytrucks.com/vboard/s...d.php?t=637478 1983 Short Fleet (Under construction for my 13 year old son) 2008 GMC Denali 2012 Harley Roadglide Follow me on Instagram: Ru_django ![]() |
#22 |
The UPS truck came to see me today with my drop spindles and disc brakes.
#23 |
Shiney !!!
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#24 |
Let the fun continue...
#25 |
are you also going to be switching the rear over to 5lug? I see you ordered the 5 lug front disks. Truck is looking good with the upgrades.
