Old 01-15-2011, 12:20 PM   #1
MattyBs71
MattyBs71's Avatar
Air Bag Brackets for my 71 C10
I've done some reading through other threads about air bag brackets but I'm getting conflicting messages.
I have a 1971 C10 with the coil spring suspension on front and back.
1) Do you need brackets on the rear? Some are saying yes to get correct ride height and some are saying no. The person that said yes you need them was a vendor so I assume he is saying this to make a buck.
2) Where are you getting your bracket kits? I see front ones at Suicidedoors and a few other places. Who has the best ones and best price? When I have looked I have only found front bracket kits and nothing for the rear.
Thanks for your time! Links would be appreciated to kits you have used!
Matt
MattyBs71 is offline   Reply With Quote
Old 01-15-2011, 01:11 PM   #2
mixermike
mixermike's Avatar
Re: Air Bag Brackets for my 71 C10
i'm also interested in this. i'm gonna convert from leafs to trailing arms. i thought the air bag replaced the coil spring without any other brackets.
mike
mixermike is offline   Reply With Quote
Old 01-15-2011, 01:21 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
No bracket needed for the rear.
Actually,... I use a lowering block also,... so my truck won't look stock at ride height.
Most people use a 2600 bag front and rear,... but some run a 2500 bag in the rear for less lift at the same pressure.
www.***************** has great prices on front bag plates and lower a-arm cups.
I like Slam Specialties bags. The re-7 or ss-7 versions of their 2600 bags.
AirLift Dominators are also an affordable choice.
Look at or site vendors for your air ride needs.
Here's a few that come to mind:
AVS
ScottsHotRods
Porterbuilt
Keith
Convert to disc brakes.
Old 01-15-2011, 01:33 PM   #4
mixermike
mixermike's Avatar
i'm looking at porterbuilt trailing arms and trying to decide which would be a good choice 2 or 3 inch drop.
did'nt mean to hijack your thread Matt
thanks guys
mike
Old 01-15-2011, 01:46 PM   #5
lolife99
lolife99's Avatar
I would run the PB 2" drop trailing arms.
Keith
Old 01-15-2011, 03:24 PM   #6
MattyBs71
MattyBs71's Avatar
Mike- Did you used to live in Enumclaw???
Keith- Do you have a picture of your rear setup? Where is the block in all of this?
Old 01-15-2011, 03:57 PM   #7
lolife99
lolife99's Avatar
I have no idea where Enumclaw is.
Here's a picture of my rusty blazer with a 2" block, bolt-in c-notch, and a Slam Specialties RE-7 bag.
No brackets needed.
Use 3/8"x4" bolt thru the trailing arm with a HD washer.
Drill 2 mounting holes and 1 air fitting hole in the frame.
Keith
Old 01-15-2011, 04:17 PM   #8
MattyBs71
MattyBs71's Avatar
Keith- Thank you! This helps. I was asking Mike if he lived in Enumclaw cause I used to and saw that truck around town I thought.
Old 01-15-2011, 04:53 PM   #9
lolife99
lolife99's Avatar
It would help if I could read. Ha.
Keith
Old 01-15-2011, 06:03 PM   #10
mixermike
mixermike's Avatar
never lived in Enumclaw.I get down that way every once in while
Old 01-15-2011, 07:41 PM   #11
lolife99
lolife99's Avatar
mixermike,... do you have any other pics of your truck?
Or a build thread?
Keith
Old 12-08-2012, 06:45 PM   #12
92sierraslx
92sierraslx's Avatar
what if your bags have dual mounting holes in the bottom then how do you attach to trailing arm?
92sierraslx is offline   Reply With Quote
Old 12-08-2012, 10:06 PM   #13
mixermike
mixermike's Avatar
I used dominators 2600 they have 3 holes in the bottom.i used 1 bolt through the trailing arm to the center hole of the bag.
Old 12-08-2012, 10:09 PM   #14
mixermike
mixermike's Avatar
Or a build thread?
Sorry Keith I missed this.....I don't have a build thread and I really need to take some better pics one of these days
Old 04-04-2013, 12:38 AM   #15
mantisman
do you have to run a tank with air ride. I'm just wanting it to keep it ride height not really interested in running it up and down.
mantisman is offline   Reply With Quote
Old 04-04-2013, 12:49 AM   #16
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Tank isn't really required. Just run lines off your bags to schrader valves and pump it up until you reach a ride height you like. It's a cheap solution for riding on air.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
