Old 04-06-2013, 10:33 PM   #1
scabby9
scabby9's Avatar
Differences between an 80 and 87 frame?
Greetings from Newfoundland, Fairly new member.
I purchased a very very long term project last fall. It's an 87 R10 Short wide and i wanted to do a Build from the frame up. Blast the frame and do an air ride set up etc etc.
The other day i came across an 80 shortbox frame that a guy sold the front clip and cab off of. Basically it's a frame with a half rusted box and a blown motor. So really it's a frame lol. If i purchased the frame and started the building process on that frame, i wouldn't have to scrap the 87 to do it. I'd really like to drive the 87 before i tore it down. Both are 2WD Short boxes.
So my question is, If i bought the 80 frame, would everything fit over on it from the 87 when i got it done? any issues at all? The guy wants $100 for the frame so $100 is a small price to pay for keeping the 87 on the road for a extra year or more.
Any opinions?
scabby9 is offline   Reply With Quote
Old 04-06-2013, 11:06 PM   #2
bdiamond
Re: Differences between an 80 and 87 frame?
There are a few differences. I think the main difference is the front frame horns. They are different but I think it would still work for you
bdiamond is offline   Reply With Quote
Old 04-06-2013, 11:22 PM   #3
scabby9
scabby9's Avatar
Thanks for the info. I did a search and found this.
http://67-72chevytrucks.com/vboard/s...d.php?t=335189
Old 04-06-2013, 11:35 PM   #4
J Knight
J Knight's Avatar
The swap is do-able, a friend and I swapped an 84 body on a 73 frame. Here are a few differences that we found=
frame horn ends but you can trim slightly to fit the 81-87 bumper
you will need to use 73-80 body and radiator support bushings, they are frame specific and not cab/rad sup specific. Don't be suprized if you have to slightly relocate the radiator support brackets on the frame(about 3/4in).
73-83 have a slightly different e-brake set up than 84-87 so you will need to use the complete e-brake cable set up for the 80 or the 87, not a big deal just swap the parts set up you choose over.
The 80 should have a right side fuel tank while the 87 should have a left side fuel tank. You might have to drill a hole or two in the frame to swap the tank mounts over but again, not a big deal. Hope this helps.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 04-07-2013, 01:12 AM   #5
KrazyRay
KrazyRay's Avatar
The rear sport bumper and brackets will need to be specific to the frame or you can drill holes to make it happen.
KrazyRay is offline   Reply With Quote
