Old 02-16-2014, 04:48 PM   #1
solidaxel
solidaxel's Avatar
4L60E shifting problems 2003 LQ4
Finally drove the truck around the block.
First gear works great, but it shifts weird
1st to third and when I try to throttle it a bit it wants to down shift!
Back to the garage
Do you think it might be the computer or the transmission, I know that is not much info, but I do not want to drive until I do some more homework.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-17-2014, 11:25 AM   #2
Custom 68
Custom 68's Avatar
Re: 4L60E shifting problems 2003 LQ4
check all your plugs to your transmission, it needs the speed and all the other inputs to function correctly.
The lq4 may have possibly been mated to a 4l80 tranny, that will require different wiring and yes the computer will need to be worked over to correctly shift the 4l60.
Do you know what computer and transmission came with that motor originally?
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 02-17-2014, 11:40 AM   #3
ls1nova71
ls1nova71's Avatar
I agree, its probably a tune issue. An LQ4 would have originally had a 4l80e behind it and if you didn't change the tune it won't work right.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-17-2014, 11:42 AM   #4
solidaxel
solidaxel's Avatar
I purchased the whole package together, but the computer was exchanged and re programed for this combo, and was to be tested as a whole unit, ECU TAC and DBW foot feed
LS 3 4L70E
Old 02-17-2014, 12:54 PM   #5
Custom 68
Custom 68's Avatar
Well that said I would call them back and find out. I do know the wiring is similar but different for the 2 transmissions. My harness had provisions for both and I mis read some of the info and hooked it up wrong and it would not work. It was my issue and I quickly found the problem.
Check your wiring first then call them.
Dave
Old 02-17-2014, 01:00 PM   #6
solidaxel
solidaxel's Avatar
I called them a few min ago and he said and they said 'Send it back", he said has programed many many of these with the same results "0" he said it was most likely a hard ware problem!.
I will keep you posted!
One more vote for finding a GOOD local programmer, turn around time!!
LS 3 4L70E
Old 02-17-2014, 09:29 PM   #7
mooseknuckles
mooseknuckles's Avatar
how many sensors in the harness for the tranny?
mooseknuckles is offline   Reply With Quote
Old 02-17-2014, 09:41 PM   #8
solidaxel
solidaxel's Avatar
Do you mean pins or contacts?
I have the old harness I will compare the quantity or pins
LS 3 4L70E
Old 02-17-2014, 09:56 PM   #9
solidaxel
solidaxel's Avatar
How is your outside C- meter this time of year!!!
Take a look at our TV KOLD Ch.13 weather this week, and the sunset pics.
LS 3 4L70E
Old 02-18-2014, 02:46 AM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
So if you have an extra plug hanging down in your harness, then your harness was wired for the second vss (ISS) for the 4l80e...if not then it should be the 60e single plug you need. Also, disconnect that plug and clean it off with contact cleaner, as sometimes trans fluid drips from the seal or seeps from the top or the pan or bolts and can infiltrate the connector. Sometimes even wiggling it will give you a sign.
Does the accell pedal work right when your in neutral, i.e does the throttle respond normally? (i assume so, as usually dbw either works or it doesn't).
If your vss is not plugged in all the way, or pinched/miswired, then the strange sensations your feeling are possible. Its also plenty possible that he didn't do a segment swap and the ecm wants the second input from the ISS, it may "think" you have an 80e.
Also, check the wiring on the brake switch, and that its adjusted properly. Lockup functions are directly affected by it and the tune, and can make trans functions very jerky and wonky.
Codes?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-18-2014, 08:51 AM   #11
solidaxel
solidaxel's Avatar
[QUOTE=BR3W CITY;6531472]So if you have an extra plug hanging down in your harness, then your harness was wired for the second vss (ISS) for the 4l80e...if not then it should be the 60e single plug you need. Also, disconnect that plug and clean it off with contact cleaner, as sometimes trans fluid drips from the seal or seeps from the top or the pan or bolts and can infiltrate the connector. Sometimes even wiggling it will give you a sign.
Codes?[/QUOTE
I like that Jerky & wonky, that is what it does on the second shift, and not second gear !!
The extra plug that I have is attached to the stock harness on the shelf.
I will pay some attention to the male part of the transmission plug as the female is clean and new.
The gas pedal is super responsive and works great.
I did replace the brake switch so that it has 12VDC with the brake off to the TCC., on the cruise end of the plug, the brake lights will go on with 1 inch pedal movement so the TCC contact is opened at 1 inch
The first thing I am going to do is count the pins!
LS 3 4L70E
Old 02-18-2014, 03:22 PM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You didn't happen to mention codes, is anything showing up? Sometimes trans codes won't pop cel the same, but I'm curious if anything is signaling.
Skipping second gear can also be a mechanical failure, like the solenoid isn't working (or getting voltage), the valve body has something gunked in it, or a physical problem with second.
We gotta eliminate 1 thing at a time haha. It would be nice if we could plug it into hpt and see if it commands second.
LOL I think we need to should put HP Tuners on the list of required parts for a swap.
Old 02-18-2014, 03:56 PM   #13
solidaxel
solidaxel's Avatar
No codes,
I did have the truck to the transmission shop and he connected "his" transmission controller to the trans. with my cannon plug removed and he said the transmission was working just fine, He thought the problem was with the computer,
I did look at the original cannon plug and counted the wires and there are 13 in each one BUT the yellow and green are transposed at the plug.
I did not follow them to the computer connector pin outs, so they MAY be transposed there which would not be a error.
The grey plug is the stock and the lighter one is new plug
LS 3 4L70E
Old 02-18-2014, 06:58 PM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Well, thats the 60e plug (the 80e looks the same but has or uses less pins). On the stock plug, the green wire should be Solenoid A, and the Yellow/black wire is Solenoid B.
Like you said, it doesn't mean that they didn't just color it wrong but wire it right, though it gives you a clear point to look at. You can wire swap those two and see if there is a change...but without being able to see into the computer, we'll still end up with a question mark on that part.
Old 02-18-2014, 10:51 PM   #15
ls1nova71
ls1nova71's Avatar
I would definitely take a volt meter and check those two wires at the PCM to make sure...
Old 02-19-2014, 05:03 AM   #16
solidaxel
solidaxel's Avatar
O K, which connector and what pin position should they correspond with?
LS 3 4L70E
Old 02-19-2014, 10:24 AM   #17
Wasted Income
Boosted Member
Wasted Income's Avatar
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-19-2014, 11:20 AM   #18
ls1nova71
ls1nova71's Avatar
Yellow/black would be the 2-3 shift solenoid and should be on C2 pin 47, the lt green would be the 1-2 shift solenoid and should be on C2 pin 48. I could see the transmission doing some weird stuff if the PCM activated the 2-3 shift before the 1-2.
Old 02-19-2014, 01:54 PM   #19
solidaxel
solidaxel's Avatar
O K, thanks I am going to prove 47 & 48 on the green connector right ?
LS 3 4L70E
Old 02-19-2014, 04:15 PM   #20
solidaxel
solidaxel's Avatar
Update,
O K I did unplug the green computer plug and pined the two positions at the cannon plug at the transmission.
I compaired them to the stock wire harness I have and they are TRANSPOSED, green and Yellow with a black tracer is backwards with the green wire per he stock harness.
NOW which end do I make the change, which is the easiest to change with OUT cutting and splicing????
The transposition is in the cannon plug, but how do I dis assemble it?
LS 3 4L70E
Old 02-19-2014, 04:25 PM   #21
solidaxel
solidaxel's Avatar
Like BR3W said JERKY & WONEY if these were transposed that is what t would shift like !!
I may not be counting the positions on the green connector properly BUT they are reversed or transposed with each other (stock & aftermarket)
LS 3 4L70E
Old 02-19-2014, 04:30 PM   #22
truckdude239
truckdude239's Avatar
I'd just swap the pins at the computer side
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-19-2014, 04:33 PM   #23
solidaxel
solidaxel's Avatar
.............. O K, I need a little O J T, will all of the other pins fall out when I figure out how to get it apart!!!
LS 3 4L70E
Old 02-19-2014, 04:58 PM   #24
solidaxel
solidaxel's Avatar
here is where I think the problem will be corrected
This is where I found the problems.
LS 3 4L70E
Old 02-19-2014, 05:07 PM   #25
Wasted Income
Boosted Member
Crap...my image of the pinout somehow turned into a huge megasquirt image. Well that's what I get for stealing stuff from their site...
Turbo diesel
