Old 06-16-2013, 02:42 PM   #1
Kaotik Kustumz
Kaotik Kustumz's Avatar
Question question bout gauge cluster....
ok heres the deal...
i got a '86 chevrolet lwb had 305 w/ 700r4 factory...
now has 350 w/ 700r4...
stock factory gauges are long gone now and am going upgrade with some from a '91 burban cause it has the electronic speedo (swapping engine and tranny for a 5.3 w/ 4l60e combo)...
ok now i wanna swap the fuel gauge out with the factory tach option and move the fuel gauge to the lower left corner where the factory clock was at....
so now what all do i need to do o make this work correctly just like the factory would?
please any info would be GREATLY appreciated
Kaotik Kustumz is offline   Reply With Quote
Old 06-16-2013, 03:48 PM   #2
Kaotik Kustumz
Re: question bout gauge cluster....
I got a '86 chevrolet lwb had 305 w/ 700r4 factory...
Now has 350 w/ 700r4...
Stock factory gauges are long gone now and am going upgrade with some from a '91 burban cause it has the electronic speedo (swapping engine and tranny for a 5.3 w/ 4l60e combo)...
Ok now i wanna swap the fuel gauge out with the factory tach option and move the fuel gauge to the lower left corner where the factory clock was at....
So now what all do i need to do o make this work correctly just like the factory would?
Please any info would be greatly appreciated
posted via mobile device
bump it on up!!!!
KAOTIK Kustumz
1984 Chevy 1 Ton Crew Cab Dually "Western Hauler"454, th400, (6.0, 4l80e Swap Coming Soon)(5/7 Drop Coming Soon) (ON HOLD FOR NOW)
1986 Chevy 1/2 Ton LWB Silverado350, 700r4, (5.3, 4l60e Swap Coming Soon)(4/6 Drop)
Old 06-16-2013, 04:14 PM   #3
gmachinz
Ok....well, I just sold my last 90-91 gauge cluster so I'm not sure on one thing.....check to see IF the printed circuit has a provision for the fuel gauge going to the quartz clock location at the lower left-if its there and just not used, you should be able to add both the fuel gauge and tach with no problem-you'll have to trim out the housing with a dremel to make it nice.
If the printed circuit does not route the fuel gauge to that spot....you'll have to re-pin the fuel gauge independant of the instrument cluster plug-in.
gmachinz is offline   Reply With Quote
Old 06-17-2013, 01:37 PM   #4
Kaotik Kustumz
so this is really all i need to know in order for them to work?
KAOTIK Kustumz
