Old 10-10-2014, 11:55 AM   #1
comicaltatertot
1st time LS swapper
Ok so I have a '72 Chevy K/20 longbed 4x4. I am looking to put a 6.0 truck motor with a 4L80. For now I just want to basically keep the motor stock, I just want to do the swap as cheap as I can now then make upgrades later.
Since this is the first time I have ever done this, I was wondering if there is a good place to start to get some basic info on how to do an ls swap?
Anything you can recommend would be great, a thread on this forum, a link to a site, a book on doing a swap.
Again for now I am just doin a basic swap any help would be appreciated. Thanks
1955 Chevrolet 3100 2nd series 235
1972 Chevrolet k/20 long bed 4x4 350
2005 GMC Sierra 5.3 L33
comicaltatertot is offline   Reply With Quote
Old 10-10-2014, 12:12 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 1st time LS swapper
We put the stickies at the top of the ls forum for just this reason.
http://67-72chevytrucks.com/vboard/s...d.php?t=456787
That, the "what ya got" thread for pictures/ideas, are great places to start. Once you've familiariazed yourself with the basics, then take a look through the builds or search for some more specifics. Once you have a simple idea of the "what", getting the "how" isn't bad.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-10-2014, 12:46 PM   #3
class01
class01's Avatar
Im kinda in the same boat. It would be cool if someone broke each part of the install down. Like fuel system: do this and this etc, order this.
class01 is offline   Reply With Quote
Old 10-10-2014, 01:31 PM   #4
comicaltatertot
Sweet thanks. I am still trying to figure out how to navigate everything in the forum I like that link pretty awesome. Hey class01 check out the link that Brew City posted good stuff.
Old 10-10-2014, 01:50 PM   #5
LS1Impala
This has to be one of the most asked but most difficult questions to answer. There are so many different options that it would be difficult for someone to give you the breakdown. They could give you their breakdown of how they did it, but its not going to be the only way. Spend some time looking through the threads on this forum and see what you like best and what you have the time/money for. Most of all have fun doing the project and dont give up, they are a blast to drive and you will not regret putting an LS into your truck!
1968 C10 5.3/4L60E LS6 cam and a 3600 stall
1968 Camaro 6.0/4L65E T76 turbo 9"
1960 Impala LS1/4L60E all stock cruiser
LS1Impala is offline   Reply With Quote
Old 10-10-2014, 01:52 PM   #6
LS1Impala
And one more thing...welcome to the club, although this may be your first LS swap it is normally not the last! They are addicting!
Old 10-15-2014, 08:08 PM   #7
comicaltatertot
Ok so I have a somewhat interesting question. I know that the LS2 is the 6.0 and I found an LS2 controller kit from Chevrolet performance. Now will that same controller kit work on the 6.0 truck engines? It says use for 58x engines only what does that mean?
Old 10-16-2014, 12:20 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
There are two different types of Reluctor wheels, for the GenIII and GenIV motors respectively.
Because of the architecture of the GenIV computer, some folks choose to control GenIV engines with a GENIII ECM and either swap the reluctor, or use the adapter-thingy that allows the signals to work with each other effectively.
You don't need that for a regular swap; you can just use the regular GenIII or GenIV ecm setups...depending on which engine you source. There are plenty of members here with GenIII swapped trucks, and a few others with GenIV swaps using the stock ecm's.
Old 10-16-2014, 02:26 AM   #9
ls1nova71
ls1nova71's Avatar
58x is a Gen4 engine and will have a gray colored crank sensor, Gen3's are 24x and have a black crank sensor. Whether it will work or not depends on what year engine you get.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
