Old 05-02-2012, 11:16 PM   #1
sigshooter
sigshooter's Avatar
66 shoulder belts
Does anyone have good pics of the rare 66 shoulder belts? I want to install them when I change my inner panel to Big Window. I have found a 66 that has the holes for them so I can use the mounting plates and get the exact location for the holes... all I need now is to know what they look like so I can have some made up.
This is what I have so far
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 04-12-2013, 12:26 AM   #2
yelmer
Re: 66 shoulder belts
hello I was checking in how was the seatbelt mount upper going ?
yelmer is offline   Reply With Quote
Old 04-12-2013, 12:35 AM   #3
sigshooter
sigshooter's Avatar
I haven't started on the big window yet, I will do it then
1966 Short stepside
1964 long bed
Old 04-14-2013, 05:29 PM   #4
HOTFUN
HOTFUN's Avatar
We just recently converted my 66 cab to a BBW from a small bw and I never noticed it had the belt anchors up there till I saw your thread just today. My 66 C30 cab chassis was made in July, 1966 and it had these seat belt anchors and plugs but my original 66 short fleet built in April-May 66 does not have them. We can't remember what the anchor looked like but it had to have a bracket with anchor nut going back to the channel on the door opening post frame work. I looked at the inner cab small panel cut out piece and there is nothing at all been attached to the backside of that panel but the bolt hole itself and plug. Wish I would have thought about that while we had that inner cab piece totally trimmed out for the BBW panel. I guess I should now keep a corner of the removed inner cab sheet metal for a hole guide if I want to add shoulder belts down the road. Should just have to cut the hole in the exact location and my nut backing should still be in place for me. Sorry.
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 factory #'s V8 stepside project
'72 Cheyenne K20 50k original
'72 CST Blazer K5 owned 30+yrs
'73 Sierra swb 4x4
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is online now   Reply With Quote
Old 04-14-2013, 08:15 PM   #5
yelmer
do you have a hole or a hole with threads ?
Old 04-14-2013, 08:44 PM   #6
HOTFUN
HOTFUN's Avatar
No threads in panel. It was a smooth clean straight hole and probably a stamped out access hole and then painted fawn on the interior side and a black plug just like in the pictures above in it. There is nothing tacked to the inner rear cab sheet metal which I have still that was removed and replaced with a BBW panel. So a nut/bracket has to have been welded to the back side of the door opening framework the only thing of subsistence in that corner. We removed the entire small window rear inner cab sheet metal piece all the way out to the post spot welds. Never even took a picture or looked at that shoulder belt mount when the cab was open.
'73 Sierra swb 4x4
'72 GMC K2500 4x4
Old 04-14-2013, 09:55 PM   #7
yelmer
must be a Janesville truck? what is the vin number
Old 04-14-2013, 10:15 PM   #8
yelmer
here are some that I cut out of a truck it has the bolt assembly
Old 04-15-2013, 12:59 AM   #9
HOTFUN
HOTFUN's Avatar
I am at work tonight but I can get the vin tomorrow. Both trucks are Janesville and one time you gave me the month the C30 was built but the engine stamp date was 0707 if I remember exactly.
I will take a shot of the back side of that panel but you can clearly see the spot welds on the front surface of the one you have and mine absolutely has no threaded hardware attached to the back of the panel. The plug looks simulair but only fits the hole.
'73 Sierra swb 4x4
'72 GMC K2500 4x4
Old 04-15-2013, 09:41 PM   #10
yelmer
from my dealings with this the Janesville did not have the bolt screw hole and the plug was appx 1/2" hole . the fremont and st Louis trucks had the screw and bolt. with a push in barbed plastic plug . I would like to know when chevy started this .I have a 3rd week june truck that has them all the july trucks have them that I have ran into . my friend has a may truck does not have them . maybe it was a 1 st of the month in june? that why I asked for vinsand buildsheets are the best to narrow down the weeks mike
Old 04-15-2013, 10:09 PM   #11
HOTFUN
HOTFUN's Avatar
I got called in a couple of hours early to work tonight and got nothing done when I woke up this afternoon. I have the plug right in my pocket and it is just a 1/2" plug with no barbed edge just fits the 1/2 hole.
I appologize but I will try tomorrow to get the vin of it. Most of my trucks are Janesville with one St Louis. This is the only shoulder harness hole truck I have and it is a Janesville truck.
So they must have started using stamped out hole sheet metal cab panels but didnt have enough new anchor hardware on hand to spot weld them in behind it? Then maybe they sparingly installed the hardware only on the trucks that were getting the shoulder belt as a factory installed option at that time? I am 99% sure my truck was early July built as the chassis went over to a camper conversion company in Kansas and was made into a 67 model walkin camper using a 66 chassis and vin.
'73 Sierra swb 4x4
'72 GMC K2500 4x4
Old 04-16-2013, 01:32 PM   #12
HOTFUN
HOTFUN's Avatar
Yelmer: 66 C30 cab chassis info right off the protect o plate. Sold new 7/30/66
VIN ce3836j164xxx engine # f0707yh
Mark
'73 Sierra swb 4x4
'72 GMC K2500 4x4
Last edited by HOTFUN; 04-16-2013 at 09:39 PM. Reason: removed part of vin and pm'd to Yelmer
Old 04-16-2013, 03:21 PM   #13
gofastnut
gofastnut's Avatar
Cool info!
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 04-16-2013, 09:35 PM   #14
HOTFUN
HOTFUN's Avatar
This is the picture of the Janesville built C30 cab inner back panel backside of the shoulder belt hole. So Yelmer would you say there was no nut/bracket behind the panel on my truck? I sure wish I would have been there when my friend cut that panel piece out and welded the big back window section in. Again this just had a plastic 1/2 black hole plug in the hole. Mark
'73 Sierra swb 4x4
'72 GMC K2500 4x4
Old 04-16-2013, 09:49 PM   #15
yelmer
there is no nut. this is a back side section that has it
Old 04-17-2013, 02:52 AM   #16
collins10672
collins10672's Avatar
i have a 66 small back window cab leftover from all of my other truck builds from the past and it has the black rubber plug for the shoulder harness belts too and it was built in flint michigan.i do not know if it just has the plug or the threaded nut.of all the 66 trucks i have owned it is the only one with the plugs.most of my other 66's were built in atlanta and they did not have them.
collins10672 is offline   Reply With Quote
Old 04-17-2013, 08:57 AM   #17
yelmer
check the vin number on the one that has it. it is probably a june or july truck . looks to me that it was at the end of the assembly run in 66 when these were installed
Old 04-17-2013, 03:00 PM   #18
sodly
sodly's Avatar
Mine's a late '66 Fremont, CA build and it has the holes/plugs.
sodly is online now   Reply With Quote
Old 04-18-2013, 02:01 AM   #19
collins10672
i will look tomorrow and get back to you.
Old 04-18-2013, 11:03 PM   #20
collins10672
the vin number is c1546f1622xx
Old 04-19-2013, 08:44 AM   #21
yelmer
looks to be june of 66 do you have threads or just holes . do you have a buildsheet?
Old 04-19-2013, 10:01 PM   #22
collins10672
i do not have the build sheet i have the cab in storage and lots of things are packed in front of it.i will try to look when i get the chance.thanks
