Old 04-28-2013, 10:16 AM   #1
allons
Panhard bar question
I'm planning on doing a 4" static drop on the rear of my '72 using drop springs. I know I don't need to notch the frame. What I don't know is can I re-use the OEM panhard bar or do I need to get another one that is adjustable? Thanks
allons is offline   Reply With Quote
Old 04-28-2013, 10:51 AM   #2
weever82
weever82's Avatar
Re: Panhard bar question
Doing a 4" drop you will be fine, most agree after 5" or more then you will need an adjustable trac bar and shock mount relocators.
Weev-
Life's tough...... It's even tougher when your stupid - John Wayne
weever82 is offline   Reply With Quote
Old 04-28-2013, 11:09 AM   #3
allons
Originally Posted by weever82 View Post
Doing a 4" drop you will be fine, most agree after 5" or more then you will need an adjustable trac bar and spring mount relocators.
Thanks for the advice, and the tip on the spring mounts!
Old 04-28-2013, 11:18 AM   #4
cdowns
cdowns's Avatar
you rear end will b off center using the stock panhard bar// the way to tell is to use a tapemeasure to see the truth
never heard of spring mount relocaters either// guy must b confused with shocks
Old 04-28-2013, 11:46 AM   #5
allons
I suspected he was referring to the shock mounts and gave him the benefit of the doubt. But, now I'm confused about my original question on the panhard bar. Do I need an adjustable bar?
Old 04-28-2013, 11:47 AM   #6
allons
It really doesn't matter to me if I need an adjustable bar or need to relocate the shock mounts . . . . I just want to do the installation ONCE!
Old 04-28-2013, 11:48 AM   #7
weever82
weever82's Avatar
Lol... Ya ment shocks but typed in springs. Haha!
Weev-
Old 04-28-2013, 12:06 PM   #8
leddzepp
Moderator
leddzepp's Avatar
You will most likely need an adjustable bar to re-center the rear end.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-28-2013, 12:14 PM   #9
allons
OK, I'm gonna go with the adjustable bar and NOT relocate the shock mounts. Yes?
Old 04-28-2013, 12:15 PM   #10
leddzepp
Moderator
leddzepp's Avatar
You should also relocate the shocks. They are angled pretty steep from the factory and dropping it 4 inches increases that angle.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-28-2013, 12:50 PM   #11
allons
Alllllllll righty then . . . . . . 1 adjustable panhard bar and 2 relocated shock mounts. The shock mounts are riveted in, so the next question is, does the new shock mounts used the old rivet holes or is it a welded in mount?
Old 04-28-2013, 12:53 PM   #12
leddzepp
Moderator
leddzepp's Avatar
They use the same holes. You will need to remove the rivets (lots of fun!).
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-28-2013, 05:28 PM   #13
bugmasta
bugmasta's Avatar
If you only want to do it once then do it right with an adjustable bar and shock relocaters.
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130
Club longbed ...cause girls like'em long!!!!!
bugmasta is offline   Reply With Quote
Old 04-28-2013, 05:31 PM   #14
hfd410
hfd410's Avatar
just grind the heads off with a flap disk and drive em out with a punch. They are pretty easy to take out if you can get to em...
hfd410 is offline   Reply With Quote
Old 04-28-2013, 05:43 PM   #15
allons
I've got the frame stripped bare and s'blasted so now is the time to get things right. Any recommendations for the best source for the relocated shock mounts?
Old 04-28-2013, 06:39 PM   #16
Sammy
Early Classics Adj bar and relocation kit. Get the one with the 4 lowered shocks. I think about $320 for everything you need shipped.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-28-2013, 06:51 PM   #17
nlped
nlped's Avatar
I used the CPP deluxe bent adjustable panhard bar, because I have a BIG aluminum diff cover that a regular panhard bar would not clear. And I used the ECE shock relocator kit that I got from a great member on here (Thanks Chad...CC69Rat)!
Picture is before I finished the shock relocator install
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 04-28-2013, 07:14 PM   #18
Sammy
My kit
Old 04-28-2013, 07:59 PM   #19
weever82
weever82's Avatar
I also rave on the ECE shock relocators and adj pan hard bar. Mine installed pretty easy and pure quality!
Weev-
Old 04-28-2013, 08:00 PM   #20
weever82
weever82's Avatar
Also it's just easier to cut off the u bolts instead of a gallon of PB and a breaker bar for an hour (don't ask me how I know, lol).
Weev-
Old 04-28-2013, 09:11 PM   #21
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
^^X2
Good quality stuff. Also, that longer adjustable track bar will work much nicer over bumps, no bump steer.
Tom Vogel is offline   Reply With Quote
Old 04-28-2013, 10:03 PM   #22
buckskins4ever
buckskins4ever's Avatar
Your best bet will be to spend the $80 to get a nice adjustable panhard. Most likely you will have a little offset anyways. You can use a tape measure (as said before) but I measure with wheels on to measure easy. You can go from underneath with at full drop and measure the gap between the top of the wheels and the bed side.
buckskins4ever is offline   Reply With Quote
