Old 04-25-2013, 10:42 AM   #1
agnes the dog
agnes the dog's Avatar
Trans/drive shaft question
Getting ready to start my T5 swap this weekend. I have gathered all the parts. I'm mustering up the courage, but have one important question. I have not yet pulled the old transmission, a stock 3 speed/column shift. Does anyone know how many splines are on the output shaft? I'm obviously going to have to have the drive shaft cut down. I want to have all the parts ready so I don't have to go hunting for the right yoke at the last minute.... I will use the old one if it will work, but will have to figure out a solution if it's not going to work.
Thanks in advance,
JJ
agnes the dog is offline   Reply With Quote
Old 04-25-2013, 12:34 PM   #2
Wrenchbender Ret
Re: Trans/drive shaft question
I'm not shure of the count but it will be different. You need a 68 up yoke. Practically any one will work except one from a TH400. You will need to get the trans. in to measure the drive shaft length.
Wrenchbender Ret is offline   Reply With Quote
Old 04-25-2013, 12:35 PM   #3
agnes the dog
Thanks!
Old 04-25-2013, 02:11 PM   #4
63 & 64 Bowties
and a few others
Lots of good info here, in case you hadn't seen it yet:
http://67-72chevytrucks.com/vboard/s...d.php?t=313954
Is this the method you're going with or the adapter plate method?
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 04-25-2013, 02:15 PM   #5
vegadesign
vegadesign's Avatar
should be a 10 spline
very common for those years
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 04-25-2013, 04:07 PM   #6
agnes the dog
I am going to use an 85 Camaro 5 speed. I currently have an 84 305 SBC in it and this one should bolt right in - haha! I have swapped in a set of leather Cadillac buckets, do I won't need to swap the tailhousing to the s10. Actually, I had already swapped to an s10 tailhousing and had to swap it back. Anyway, the Camaro trans has a mechanical speedo drive, which will make life easier. Just gotta figure out how to find a new yoke.
Old 04-27-2013, 12:05 PM   #7
sweet70beast
sweet70beast's Avatar
I used a 92 V8 Camaro T5 in my Nova and used a TH350 yoke, it fit right in. This one had the electronic speedo but it used gears to spin the electronic sensor. BTW a speedo bullit from a TH350 fits perfectly in the hole so I could hook a cable to it.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 04-27-2013, 12:14 PM   #8
agnes the dog
Great info. Thanks!! Today's the day I start the project. Dropping the family off at the airport for a week in Florida, then it's home to get greasy!!!
