DJM WRONG BALL JOINT Question
Bought A set of upper and lower A arms off a buddy on the cheap.
Upper: P/N CA2355U, CA2356U, CA2455U 1963-1987 CHEVY C10 Lower: CA2356L-3 They have a 3" drop. I'm 99% done installing ECE's 4/6 drop kit, except when I put their spindle on I started threading the castel nut......and threading it.....and threading it. WAY past the hole for my cotter pin. So, can I buy any brand ball joint for my specific make/model/year for direct replacement? or does it have to be DJM specific? Thanks in advance for the help!!! J
http://http://67-72chevytrucks.com/v...d.php?t=578181 |
I am a Referee of life.
Re: DJM WRONG BALL JOINT Question
The Ball joints changed thru those years.The taper inside the spindle and the one outside the ball joint need to match.Sounds like you have the larger diameter spindle and smaller dia Ball Joint.ECE should be able to tell you what Ball joints work with their spindles.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Called ECE, turns out I need a joint from 63-70. Easy fix, waiting for them in the mail!
