Old 05-30-2013, 10:08 AM   #1
cantada
Exclamation LCA U-Bolt Replacement
This may not be a good idea, but I got a set of the 73-87 u-bolts coming and an trying to figure out the easiest way to change them. Can I do one at a time with the spring in place or do I have to separate the lower ball joint and remove spring first to change the U-bolts ? Opinions? Thanks.
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=518877
cantada is offline   Reply With Quote
Old 05-30-2013, 10:39 AM   #2
1963c-10
1963c-10's Avatar
Re: LCA U-Bolt Replacement
I would remove the spring. They are not something to mess around with considering the amount of tension under load.
1964 Short bed trailer
Old 05-30-2013, 10:57 AM   #3
Rich 5150 69
Rich 5150 69's Avatar
As Jon says, any other way would be suicide.....!
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 05-30-2013, 12:38 PM   #4
Clyde65
Clyde65's Avatar
I would take the spring out personally.
Another way that I wouldnt recommend is to use spring compressor to keep the pring compressed and then change one at a time.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-30-2013, 04:35 PM   #5
Sharps40
REmove the spring. I tried it one at a time and with spring pressure and working around the cross shaft, it sucked and was dangerous. Jack stands slip around, the cross shaft gets in the way....things got better and safer once the spring was out and I could drop the entire lower control arm and shaft out of the way.
Sharps40 is offline   Reply With Quote
Old 05-31-2013, 12:15 AM   #6
Z POPPY
Rent a coil spring compressor. Compress the coil spring with it installed on truck. Make sure coil pressure is off the control arm. Replace one u bolt at a time. AutoZone rents tools for free with a deposit or just about any parts store.
Z POPPY is offline   Reply With Quote
Old 05-31-2013, 09:26 AM   #7
cantada
So I bit the bullet and removed the springs. I have recently done the ball joints so it wasn't too bad. I am becoming an expert in spring removal... lol. Those new LCA u bolts are way beefier. It appears that at some point one of the u bolts had been replaced (pass rear) with the larger ones. The remaining three were the originals. Hardest part after the springs were unloaded was reaming the holes away from the cross member a bit to clear the 7/8 nuts on a couple. Stockers were 5/8 nuts. Thanks again guys!
Old 05-31-2013, 05:42 PM   #8
gofastnut
gofastnut's Avatar
Hey Cantada,
Where'd you get the u-bolts from?
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 05-31-2013, 05:44 PM   #9
cantada
Rockauto.com. Dorman part number 13503. Nice and beefy.
Old 05-31-2013, 08:00 PM   #10
gofastnut
gofastnut's Avatar
Thanks Man!
Jeff
C-10 Club
