Old 01-27-2014, 02:05 PM   #1
nolimitssjca
Wheel Cylinder won't come loose
I have a 1970 C20 that has suffered from low stopping power (4 drum brakes) since we bought her. This weekend my son and I finally bled the system and put on new front brake shoes. During the bleeding process we found the drivers side wouldn't bleed. Putting a new wheel cylinder in sounded like a good idea.
But before we did that we took a test drive and found that the bleeding process really improved the power. So next we put on new shoes. While I had the drivers side off I tried to take of the wheel cylinder but the bolt under the spindle was stuck tight and rounded. I tried a closed wrench but it won't grab and the open end slips off under minimal pressure. There is almost no room to access this thing. The bolt in front of that came loose okay but now I'm stuck.
To make matters worse it appears the brake hose is frozen on both the wheel cylinder and the brake line.
Does anyone have a suggestion about how to gain access to the bolt behind the spindle or any tricks to free up the brake hose? I'm afraid of rounding it too.
nolimitssjca is offline   Reply With Quote
Old 01-27-2014, 05:19 PM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: Wheel Cylinder won't come loose
You could try heating it with a torch.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-27-2014, 05:45 PM   #3
cdowns
cdowns's Avatar
if you only have the one bolt holding the cylinder in place?? get a pry bar on the cylinder and snap it off
Old 01-27-2014, 05:47 PM   #4
72bowtiestepper
I had the same problem with my rear brake cylinders on my 72 C-10...just chiseled off the bolt heads....use new bolts (grade 8) when replacing with new cyl. I would replace the hose with new also....might have to do the whole line if rusted too bad....don't take a chance with brakes !
72bowtiestepper is offline   Reply With Quote
Old 01-27-2014, 06:13 PM   #5
Daner
Daner's Avatar
If a flexible line doesn't want to come off the cylinder I usually just cut it and put a socket on it. Heat helps too.
I would torch the rubber line to brake line connection also. Just be careful not to twist the metal line. Heat and cool several times squirting with penetrating oil whenever.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
Old 01-27-2014, 06:46 PM   #6
71Dually
71Dually's Avatar
Forcing with a pry bar can potentially damage parts you don't want damaged, like bending a backing plate. Try the old hammer chisel trick on the rounded wheel cylinder bolt.
Is it possible to remove the backing plate from the spindle to gain better access to the wheel cylinder bolt? That would be my preferred way to go to access and remove that pesky rounded bolt.
Regarding a seized flare nut to brake hose connection there are four methods you can use to loosen this type of connection. The methods are penetrant, impact, grinding and heat. I would use them in that order and only use heat as a last resort as brake fluid is flammable. It's flashpoint is not like gas or alcohol but it is flammable so take necessary precautions when using any open flame heating operations.
Use only flare nut wrenches to help prevent rounding off both fuel and brake line flare nuts.
After allowing the connection to soak in penetrant position both wrenches so you can "squeeze" them together like plier handles to loosen the nut. This provides better leverage and control then trying to push or pull them "apart". It also helps maintain proper wrench orientation on the fittings to prevent rounding. if necessary you can lengthen the wrenches by using the box end (or closed end as you call it) of a wrench on the open end of the wrenches on the fittings. Same principle of using a pipe on a breaker bar to get more leverage. Again use the squeeze method for better leverage.
The following is a two person job. Presuming you have cut the rubber hose to remove the backing plate from the spindle you can get a box end on the rubber hose fitting near the brake line flare nut for a better grip. Get a hammer or another "anvil" type device and hold it tightly against one side of the hoses fitting connection where the threads are. Using another hammer impact the opposite side of the connection. You are basically trying to impact the exterior portion of the hose connectors threaded portion by smacking that between the 2 hammers. At the same time as one person smacks the connection another individual applies firm even wrench pressure until the flare nut connection breaks loose.
It is necessary to impact the threaded portion of the hose connection but be careful to not hit it so hard as to deform the fitting as that will also deform the flare nut and brake line at the same time since they are both hollow and can collapse. Only hit it hard enough to break the connection loose.
Next comes grinding. You basically grind a section of the material away on the hose connection until you just reach the outermost part of the flare nut thread. You will only need to grind a section and not the whole fitting. You are only trying to create a "crack" the length of the threads in the hose fitting that will weaken and then allow the connector to expand when the flare nut is turned. Creating an additional crack on the opposite side of the connector will aid in expansion if necessary. Be careful to not grind so far as to damage the threads on the flare nut.
Try a practice run on a nut and bolt to familiarize yourself with the process and concept by grinding the nut down to the bolt threads. That way you will see what the "break-thru" process looks like when you approach the top most portion of the bolt threads. If the nut spins on the bolt during the practice run secure it with another nut by tightening the nuts against each other on the bolt. Remember to only grind down to the very edge of the threads on the fastener you need to retain so they are not damaged. This grinding method is the same concept as using a nut splitter but like a box end wrench you are not able to put a nut splitter on hose connection fitting
The last alternative is heat but be careful as brake fluid is flammable so have an extinguisher close by. Most likely this method will not be needed as I've always found the grinding method works. Using a torch heat the hose connection at the threaded portion a dull red hot and the flare nut will loosen right up. Only heat the hose connection as heating the flare nut could damage it.
The four methods (penetrant, impact, heat and grinding) are basically breaking the grip that rust has on the threads of the two separate parts. If none of these work to separate the flare and brake hose you may need to get a new piece of straight brake line and bend a new line up. You'll need a double flare tool and a tubing bender to do this. You may not use these tools often but they are handy to have when working with both fuel and brake lines.
Rust in brake line connections could indicate rust inside the brake lines as well. I agree with 72bowtiestepper that you don't want to take chances with your brakes and you should assess if your brake lines need replacing. Also agree that yes use grade 8 fasteners on brake components. And as Daner has pointed out do not twist the hard steel lines.
Hope these methods will assist with your conundrum. Good luck.
1971 Chevy C30 Custom Camper Cab Chassis Dually 402 TH400 4.10:1 Eaton HO72
1969 Ford Mustang "Mach 1" 428CJ 4 speed "R Code"
1970 Mercury Cougar "Eliminator" 351C-4V C6
1972 Ford Ranchero GT 351C-2V C6
1974 Honda XL-350
Member of the "6 C's and a D" 1-Ton Fun Club!
71Dually is offline   Reply With Quote
Old 01-27-2014, 07:02 PM   #7
71Dually
71Dually's Avatar
One last thing on twisting the hard lines.
Always hold the flexible hose while you loosen the flare nut to prevent hard line twisting and damage.
A little penetrant between the flare nut and hard line will also help prevent binding that can also twist the hard line.
If you hold the flare nut and loosen the flexible hose you will twist and damage the seating surface on the hard line. Then the hard line will need to be replaced.
Again good luck, hope this helps.
1974 Honda XL-350
Old 01-27-2014, 11:17 PM   #8
nolimitssjca
Thanks for all the good advice. I have about 2 weeks before I get to try and replace these things again. I think trying to shear off the top of the bolt with a chisel is my best 1st option.
The good news is the beast has great stopping power gain. But it pulls left. I'm thinking the cylinder is toast. I'll replace both when I get back too it.
Old 04-07-2014, 11:00 AM   #9
seth7843
seth7843's Avatar
Any updates? I went to change the front wheel cylinders on my 67' C20 and ran into the same problem with the second wheel cylinder bolt being almost impossible to get to. I eventually got the cylinder out but I'm wondering how I will tighten the bolt when I install the new cylinder. My only option might be to take the backing plate off the spindle?
seth7843 is offline   Reply With Quote
Old 04-07-2014, 01:46 PM   #10
nolimitssjca
I haven't had the chance to work on it again. You should be able to simply tighten it with the wrench. It should take high torque. My issue is breaking 44 years of rust.
